Vic Jr & Intake Leak
Old Aug 18, 2009 | 09:13 PM
Sleeper04's Avatar
Default Vic Jr & Intake Leak
I bought a Vic Jr from another member and was going to install it on my newly built and bored 5.3-5.7. I have 317's on it as well. The problem is, I installed new LS1 intake gaskets and when I put on the Vic Jr, it leaks. You can hear the squealing of it pretty clear. I can get a .002 feeler guage in between but the marks on the heads show to have a good seal. Anybody else have this issue or have suggestions?? Thanks.
Old Aug 19, 2009 | 10:31 AM
team39763's Avatar
I had a problem with leaks. My first problem was that I didn't follow the bolt tightening sequence. Then the gaskets got blown to shreds and it was leaking real bad after that. I just replaced the gaskets and made sure to follow the sequence and not retighten any of the bolts after the first pass.
Old Aug 19, 2009 | 08:06 PM
Sleeper04's Avatar
That's what I can't figure out. The gaskets are brand new and I followed the tightening sequence. I only started it and let it idle for a couple of minutes while trying to find where the leaks are coming from. All the surfaces look clean. It just doesn't make sense!!
Old Aug 19, 2009 | 10:04 PM
team39763's Avatar
Maybe it's not the intake gaskets. Is it possible to have leaks around the injector seals/o-rings?
Old Aug 19, 2009 | 10:07 PM
GMCtrk's Avatar
spray carb cleaner in there and see if it changes idle
Old Aug 20, 2009 | 08:14 AM
Sleeper04's Avatar
Wouldn't you be able to see fuel leaking out too??
that's the next step I'm going to try.
Blue03sss
Mar 7, 2019 05:06 PM
tweeder
Sep 18, 2015 11:02 PM
noproblems209
Aug 10, 2015 06:57 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Ketis
Jul 23, 2015 12:37 PM
