vibration at 115
Old Jan 29, 2004 | 07:08 AM
2003blue5.7's Avatar
ok dumg question where are you getting the 140 mph from my gage only goes to 120. where can you get a different gage?
Old Jan 29, 2004 | 07:31 AM
onyx's Avatar
14 Second Truck Club
theyre using stuff like viewing softwares and tuning tools and what not...
Old Jan 29, 2004 | 08:52 AM
Originally Posted by O3GMC
only about 12k miles on the truck. The driveshaft had been removed when they pulled the tranny to install the yank 3k - but other than that it hasn't been touched. It doesn't vibrate at any other speed.
Have you checked you pinion angle and the output shaft angle ?
If so are they the same ?
Old Jan 29, 2004 | 12:50 PM
I didn't have vibration issues until I got my gear swap. I think that they did not cinch down the driveshaft correctly when they put it back in, and I believe this is part os why it blew, but I could be wrong.
I just used the predator on the truck, and it has a mph gauge, but I don't know how high it goes up to. Someone else told me that theirs would not show over 105mph. I got mine to 135mph.
Old Jan 29, 2004 | 02:11 PM
6gear's Avatar
I used a GPS, 4.10's with a Denny's aluminum driveshaft
Old Jan 29, 2004 | 04:19 PM
[QUOTE=hodgeee]I didn't have vibration issues until I got my gear swap. I think that they did not cinch down the driveshaft correctly when they put it back in, and I believe this is part os why it blew, but I could be wrong.
Could be or.....
They tightened the ubolts on the ujoints too much - it will crush the cap
and ruin the needles. esp if they hit it with a 3/8 impact...
Check the bolts - bet this is the problem.
If the bolts are overtightened - the u joint will need replaced.
Old Jan 30, 2004 | 08:17 AM
onyx's Avatar
ugh......ok..........so... should i get a new/stronger driveshaft????????
Old Jan 30, 2004 | 11:44 AM
onyx - I dropped mine with 2" shackles and I have a vibe at 12 mph (did not do the C/B relo yet - and I plan on a 2/4 drop
I am seriously thinking about another shaft. esp the rear one
Not sold on the rear shaft on our EC trucks
The shaft is thin and tapered and steel.
My 1991 shaft was alum/composite - much better.
Old Jan 30, 2004 | 11:55 AM
O3GMC's Avatar
12 Second Club
[QUOTE=LS1csherm]
Could be or.....
I'd be willing to bet the guy that put in my stall over tightened the u-joints....he used that impact on practically everything. But I just dont know if its worth messing with because the truck drives fine at any other speed. And there is no reason for me to go 115.
Old Jan 30, 2004 | 03:08 PM
Keep an eye on it...if that is real problem - that joint will fail down the road
