VaraRam Velocity stack - who wants to try a free one?
Old Aug 9, 2004 | 07:27 PM
  #31
tbyrne's Avatar
These were sent out a few weeks ago. I'll need your last name to check on this for you.
Thanks,
Tom
Old Aug 9, 2004 | 08:29 PM
  #32
moregrip's Avatar
what a rush!
email sent.
Old Aug 9, 2004 | 09:03 PM
  #33
tbyrne's Avatar
I can check on that in the morning.
Old Aug 9, 2004 | 09:04 PM
  #34
moregrip's Avatar
what a rush!
very cool, thanks.
Old Sep 22, 2004 | 11:06 AM
  #35
ridered's Avatar
so the conclusion is that the stack will work with electronic throttle control but only with the stock intake? I was getting ready to order a FIPK from K&N but I will have to rethink it if these two dont work out together.
Old Sep 22, 2004 | 11:18 AM
  #36
Originally Posted by tbyrne
You don't see this offer to often - We're going to be giving away a total of 10 VaraRam Velocity stacks for you guys to test. This will be broken up between LS1Tech and another site (5/5). Customers that would like to get one of these will just need to pay for shipping (usually between $6.-$8.). You can then install the stack and post your results back to the board.
Features:
Designed to produce power and torque throughout the RPM range
Increases throttle response
Increases gas mileage
Increases acceleration
Installs in just minutes!
A patent-pending design!
Eliminates the need for a ported throttle-body by smoothing and reshaping the throttle-body entrance to increase the incoming air velocity at each given RPM
This is what you have to do to get one of these -
1. Let me know in this thread and leave your first name/last initial.
2. I will provide the first 5 requests a number for you to use when you place your order. This will help us keep track of everything.
3. You can then call your order in or submit it on our website. Please include the number I provide you with your order.
Tom
would love to try one & I am willing to give track & dyno data
Old Sep 22, 2004 | 11:28 AM
  #37
BLACKND's Avatar
I'm with Tom on this one. I ordered one about a month or so ago and installed it in my 2004 Sierra with the electronic TB. No problems so far. And I am running it with my AirRaid MIT tube, so it definitely will work with that tube. I again will not say that I gained a lot of power, but the throttle response is better and noticed a little power down low and higher in the powerband also. I also gained about .5-1 mpg, as much as 2-2.5 mpg depending on how I drive the truck.
I don't see why you were having troubles with it on the electric TB though. Did you make sure you got it installed all the way in and used the provided clip to secure it?
Old Sep 22, 2004 | 11:33 AM
  #38
nitrorbc's Avatar
Originally Posted by 2003Silvyrado
They do not work in electronic tb vehicles. At least not in mine. It gave me a reduced engine power message every time I gave it gas. I reset the battery twice.
They are designed for the cable tb's, on the electronic ones they completely cover a hole for some sensor and only partially cover them on the cable ones.
Thusly, they -do not- work in 03/04 trucks, unless someone can prove me wrong.
I second that, I felt a loss in power.
Old Sep 22, 2004 | 02:29 PM
  #39
BLACKND's Avatar
I dunno? Seems to be working fine on my 04. Not trying to say that it won't cause problems or anything on the electronic TB's. Just that it hasn't on mine
Blwn99x
Mar 24, 2023 11:14 AM
dsbodley
Nov 14, 2015 09:46 PM
thewrx
Oct 6, 2015 10:59 AM
91LT16SpeedFormula
Oct 1, 2015 08:57 AM
