Vacuum.
Old Dec 24, 2009 | 04:19 AM
viciousknid's Avatar
Where's the Beef?
thanks. Gonna try to do that next time we are both at work and the temp is bear-able. Probably Monday.
Old Dec 24, 2009 | 04:22 AM
2005 Silverado's Avatar
SPAM HUNTER
Also spray the brake booster hose (if its not hydro-boost) and check the hoses for the crank case.
Old Dec 24, 2009 | 09:26 AM
TURBHOE's Avatar
when i had a vac leak i put a hose fitting in a cup and installed that into the intake. then i pressurized to about 15psi. found out my injector "O" rings were leaking.
either way by pressurizing the intake that way i was able to listen for leaks with out the engine running in my ear. i would suggest rotating the engine by hand a little at a time because you will here the air going past the valves.
Old Dec 24, 2009 | 06:42 PM
Where's the Beef?
didn't consider the orings.
Had thought about those on my dads truck tho. Thanks
Old Dec 29, 2009 | 12:02 AM
Tall_n_turboed's Avatar
i had the same problem twice i unpluged the maf and that made it stop the first time so i replaced it and that fixed it than like 3 months later it did it again because my IAC started getting stuck so i cleaned the TB and replaced the IAC and its worked perfect ever since
Old Dec 29, 2009 | 12:17 AM
Mangled03gmc's Avatar
Baltimore Whore
Take a butane tourch and just use the butane while the truck is running click it, so just butane is coming out. Run it around all the areas of gaskets, hoses. If it revs/idles up near one that will be where the leak is.. Or do the FP reg thing that D said
Old Dec 29, 2009 | 01:21 AM
Dewey's Avatar
i don't have any good solutions to your problem but i'll say that i had to replace my intake gaskets a while back and they are apparently a pretty common problem on the 5.3 engines. i think i had to do it around 70k or something along those lines... i have the receipt around here somewhere. cost me like a hundred bucks
2500ZL1
Sep 12, 2015 03:50 PM
MikeGyver
Mar 3, 2014 09:00 PM
therock
Aug 2, 2013 11:57 PM
kalebm22
Jul 24, 2012 11:07 PM
