V6 to V8..different fuel pump? (2003 silverado)
Old May 24, 2010 | 11:32 PM
Cook's Avatar
Default V6 to V8..different fuel pump? (2003 silverado)
What did you guys do when swapping from v6 to v8 since the 8cyl is a returnless system? do you plug the port on the tank? or do i need a new fuel pump?
Thanks in advance
Cook
Old May 24, 2010 | 11:59 PM
2005 Silverado's Avatar
SPAM HUNTER
My 05 4.3 was returnless but yes you could just cap off the return, OR you could just go return style.
Old May 25, 2010 | 08:19 AM
Cook's Avatar
what do I cap it off with?
i have the returnless v8 fuel lines and injectors
Old May 28, 2010 | 09:57 PM
Cook's Avatar
FYI....the fuel pump cant just be swapped in
Old May 28, 2010 | 10:00 PM
SPAM HUNTER
Why cant it, its the same pump. Im using the stock v6 pump...been working fine.
Old May 29, 2010 | 04:15 PM
Cook's Avatar
to use the returnless fuel rail u need the returnless fuel lines, to use the returnless fuel lines u need the returnless fuel pump, to use the returnless fuel pump u need a different gas tank, to run the returnless fuel pump in the new tank u need a new chassis harness, to vent the new tank u need the new evap system, to run the new evap system u need to fab up a bracket unless your front crossmember already has it for the new style.
lol yup, just did all this. i know i couldve got a return style rail, or used a Corvette fuel filter and rig something up, or even drill a hole in the gas cap to vent it, but we did it the OEM way
5.3Okasai
Mar 9, 2022 01:07 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
wrb002
Aug 31, 2015 12:00 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
