Used Whipple....
Old Jan 8, 2004 | 10:48 PM
Allgonoshow's Avatar
Cool Used Whipple....
I have the chance to get a used whipple from a customer of mine in about 2 weeks. I will put his truck back to stock and get a deal on his blower for the labour. He is selling the truck, his is a 2000 suburban 5.3 and mine a 2000 silverado 5.3 and I assume this is a direct swap.
If this deal goes thru I will post later for any uninstall/reinstall tips you folks
may have.
My question now is one the fmu or computer, has whipple updated that for units that were installed in 2001 and is there any reason to get an update if there is one? I don't think they are cheap.
Hope I get it, I've been wanting one of those things for a long time.
Old Jan 9, 2004 | 09:24 AM
GREGGO's Avatar
may have.
It should be a direct swap.
Not sure what your asking here. Maybe it's just my day to not be able to read.
Old Jan 9, 2004 | 09:51 AM
BigTex's Avatar
I'll answer your question. Yes, Whipple is constantly updating their computers program. Yes, it is expensive. No, it is not necessary. No, I wouldn't spend the money for the update.
From what I remember, Whipple wanted $600-$800 to update the system I had. It may even be more if they try and sell you updated hardware. One think I know about those guys, nothings free.
I think their solution for adding fuel is a poor choice. They add the two extra injectors to the intake, and use their computer to estimate when and how much fuel to add. Most other supercharger kits do a much better job by shipping out new larger fuel injectors and a custom PCM tune for the truck. Several of us here have removed the whipple computer, added larger injectors, and ran custom tuning with good results.
I say buy the kit for a good price, and run the stock system. If / when you want more from it, go with injectors and a custom PCM tune. You'll have better results than the Whipple computer will give and probably be cheaper too.
Old Jan 9, 2004 | 10:00 AM
00z71sierra's Avatar
Try to give them a call and see what they say. There have been numerous updates and are you getting the two belt setup or single?
I have the double and the single is better because it doesn't use their piggybacked crank pulley; just the stock one. Also earlier ones, you had to drill the exhaust pipe for EGR sensors. The newer ones tap in through the o2 sensorl. The newer ones also use an electric bypass which works through the Whipple cpu. If you try to disconnect the Whipple harness to run your own tuning the bypass will automatically close limiting boost. The older one is a mechanical one.
Hope this helps.
Old Jan 11, 2004 | 07:34 AM
Default Thanx for the info
I contacted wester's garage for their opinion on injectors and whipple fmu.
they said install 8.1 injectors, forget about the whipple fmu/injectors, and leave the rest to them. I beleive what they
do is program me a new computer and send it to me. There is no one in my are that can do a dyno tune so this sounds good to me
David
Old Jan 14, 2004 | 12:30 PM
Default Older style whipple.
Hope this helps.
The kit I am buying has a 2 belt setup so it must be the older one with a mechanical bypass, I assume that would be preferable to electronic if I am going to do a custom tune rather than using the whipple FMU.
Anyone know if there are any issues with the mechanical bypass and a custom tune?
David
Old Jan 14, 2004 | 01:32 PM
I had a Westers custom tune with the Whipple and still had KR. They told me that their PCM would take care of it. After 3 PCM it still did not however it did make better performance. I agree though that Westers has the best guarantee. They are giving me my money back after I have patiently tried their PCMs. I would recommend them to anyone but more than likely will be better for non supercharged applications.
slowlsx
Aug 12, 2009 03:07 PM
Kerr
Sep 26, 2006 07:57 PM
