Used LS1 advice needed!
Old Dec 13, 2006 | 07:31 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Default Used LS1 advice needed!
I need some advice,
I found an LS1 engine locally for $350, advertised from private seller as
ALUM BLOCK, ALUM HEADS, COMPLETE ENG CORE
I asked what all was included and where it came from and this is his response.
I have had the core for awhile i got bought it from a guy that worked at a gm dealership . its a warranty engine that smokes . if u want i will pull the heads off 4 u. As
it sits now it has oil pan block crankshaft piston con rods timing cover heads vavle train and vavle covers
Does this sound like something good to work up a 383 from or could there be issues with the engine block? $350?
Thanks, Bill.
Old Dec 13, 2006 | 07:41 AM
ZR1 DREAMING's Avatar
Any chance you can go and check it out? Having the heads off will give you a good chance to see the bore and combustion chamber.
Old Dec 13, 2006 | 07:52 AM
trever1t's Avatar
He offers to pull the heads but frankly I'm not certain I could identify an issue unless it was obvious. What should i be looking for?
Old Dec 13, 2006 | 08:18 AM
14 Second Truck Club
To me, it sounds like a bad oil ring. Yeah, check the cylinder walls.
Old Dec 13, 2006 | 09:45 AM
Last Call's Avatar
TOTM: January 2007
Porbably the most inportant thing is the cylinder walls. Take a flash light to them and make sure they are not scored. If they are, you would have to have them sleeved which is a lot of money. Not sure if it would be worth it. I think if you were to go with a 383, you go with new pistons and rods, so I would not be as worried about those.
Old Dec 13, 2006 | 09:52 AM
trever1t's Avatar
So if they are not gouged it's cool? How deep if at all can a scratch be? up to .003" So like a fingernail should not be able to sop on it? I would have them honed anyway. and all new internals, of course.
Is $350 about right, cheap for a good ls1 block?
Old Dec 13, 2006 | 11:58 AM
there shouldn't be any scratches at all, if there are they must be shallow enough to bore out.
Old Dec 13, 2006 | 01:03 PM
Zick's Avatar
What year LS1? Early 98-00' you could only hone the cylinders about .002" because the cylinder sleeves were very thin. The later years had a little thicker sleeve that you could bore I believe .010"
Old Dec 13, 2006 | 01:07 PM
trever1t's Avatar
That was my next question. Does year matter for a build or not? How can I identify a mfg year, any codes?
I just talked with him and he's going to pull the heads so I can see it Saturday.
$350 sounds like a deal, the heads alone are worth $200, right?
Old Dec 13, 2006 | 01:12 PM
Zick's Avatar
If the heads are the factory ones, I know the earliers years had primeter bolts for the valve cover and the later ones had center bolts.
