??upgrading injectors in ProCharged Yukon??
I'm going to be upgrading my injectors to 43lb injectors for my Procharged Yukon. Will the inline pump that came with the Procharger be sufficient? I will need to ditch the FMU. Any other tips??
Yes the inline will be sufficient. Yes, the FMU needs to go.
I can't remember his username, but his name is Sam. He put his ATI on about the same time you did, maybe a little later. He posted on FSC some too. He did this I remember and had some good info on it from what I remember. You might try doing some searches for his stuff.
ProCharged LM7 might have been it. His original username was samuriarte or something like that.
cool, thanks for the info.
BTW Black BLown 02, what do you plan on doing with your TT3000 once you upgrade.
I got the ASM ones. It was a choice between those or the Racetronix, but I don't have paypals so I went with the ASM's. Are they the same???
