Upgrades to go with Radix
Old Oct 21, 2004 | 12:12 PM
Todd@AZPowerAndSound's Avatar
Default Upgrades to go with Radix
The kit comes with just about everything. Im guessin I need plugs though. NGK TR6 the best way to go?
Anything else Ill need to upgrade?
Old Oct 21, 2004 | 12:32 PM
zippy's Avatar
pulley, heat exchanger, and programming.
Old Oct 21, 2004 | 12:33 PM
Silver-Dollar's Avatar
maybe some good tires. Not sure where you would get those.
Old Oct 21, 2004 | 12:37 PM
tr6 is the plug of choice though?
heat exchanger? programming on the way.
Tires? Hahahahahhaha I'll be runnin on 22's. Yea, smoke show. Smallest I can do is 18's because of my brakes...but I just cant lose my 22s
Old Oct 21, 2004 | 12:41 PM
GoldenVelvet's Avatar
Trans. If your going to drive it like you hate it your trans (assuming 4l60e.?) will not last too long.
Old Oct 21, 2004 | 01:08 PM
GEAR M UP's Avatar
Pulley size, larger heat exchanger, e-fans, tranny upgrade, TC, heads, cam, headers, free flow cats, exhaust, Alcohol injection,Chillers
Old Oct 21, 2004 | 01:11 PM
Flyer's Avatar
Shift kit and servos for sure on the tranny! A good exhaust will help it out a lot, I say true duals, 2.5" pipe with good free flowing mufflers. A cam will wake it up too, something small though.
That would be a good start.
Can you get us the hook up on some tires? I'm fixing to be in need of some.
Old Oct 21, 2004 | 01:36 PM
Mr. Sandog's Avatar
If it's a new kit, you already have the upgraded heat exchanger, so you're covered there. TR6 plugs are best for the Radix with 42# injectors, though the regular ones are fine, iridiums not necessary.
The #1 mod IMO is a tune...the Superchips tune that comes with the Radix is super conservative (rich) to prevent detonation. From there, I say run it for a few hundred miles before you decide on further upgrades.
Keep in mind that an aftermarket tune voids your Radix warranty...
Old Oct 21, 2004 | 01:38 PM
moregrip's Avatar
what a rush!
whats the TR6? which brand?
Old Oct 21, 2004 | 01:42 PM
Mr. Sandog's Avatar
NGK's...found here...you want the 50-TR6's.
