Upgrade on truck 6.0
Old Aug 5, 2004 | 07:18 AM
L82gofast's Avatar
Originally Posted by nativetexan
From what I understand the 6.0 really comes to life after a good tune. Guys that are getting a Nelson Tune for their 6.0s are really saying WOW after he tunes it.
Yep!
Old Aug 5, 2004 | 07:44 AM
6.0 modified's Avatar
I just bought a 2002 6.0L out of a wrecked 2500, I hopeing it is a LQ9 motor, they already had it removed from the truck, so how do I find out it is a LQ9? anway, I am having the block bored and made into 408 C.I. so I don't think it will matter if it is a LQ4 or an LQ9, The blocks are the same, the diff in HP, they are getting out of the tunning and the way the heads are set up
Old Aug 5, 2004 | 09:00 AM
marc_w's Avatar
I don't think it's a LQ9 if it came out of that truck... I think the only way to tell would be to check the glove-box codes.
But yeah, if you're putting in a new rotating assembly, it won't make any difference.
Old Aug 5, 2004 | 09:20 AM
moregrip's Avatar
what a rush!
2500 = LQ4. Not much difference between LQ4 and LQ9.
my 6.0 is rated 300hp, 360 ftlbs. there's speculation that the truck LQ4 is ether detuned or underrated.
Old Aug 5, 2004 | 11:27 AM
greentahoe's Avatar
The LQ9 has more compression. It has different pistons.
Old Aug 5, 2004 | 11:38 AM
F8L Z71's Avatar
Exactly. The intake is the same as are the heads. It's a compression and most likely something in the PCM that makes for the extra power.
I didn't want to get a 6.0L when I bought my truck because I believed the specs form GM and it seems like a waste. I was wrong. With the same mods on a 6.0L as I have on my 5.3L I would have been solid into the 13s N/A. My buddies truck weighs 500lbs more than mine and he smokes me on a daily basis with similar mods. I just can't compete with the extra cubes.
Old Aug 5, 2004 | 11:56 AM
moregrip's Avatar
what a rush!
6.0 HP ratings
325 @ 5000 rpm
GMC Sierra Denali
320 @ 5000 rpm
GMC Yukon Denali/Yukon XL/XL Denali & Suburban
315 @ 5000 rpm
H2 (prelim)
300 @ 4400 rpm
Chevy Express, GMC Savana, 3500 series, 2500 HD & 3500 GMC Sierra and Chevy Silverado pickup and crewcab
6.0 TQ ratings
370 @ 4000 rpm
GMC Sierra Denali
365 @ 4000 rpm
GMC Yukon Denali/Yukon XL Denali
360 @ 4000 rpm
GMC Yukon XL/Suburban, Chevy Express & GMC Savana 3500 series
H2 Prelim
2500 HD & 3500 GMC Sierra & Chevy Silverado pickup and crewcab
Old Aug 5, 2004 | 01:48 PM
vVandals909's Avatar
So how much hp and torque will a tune add? Also is the tune one of those programmer things? What other mods will make the motor come alive. Also this is going to be in a 3/4 ton truck. So i dont need fast just more power.
Old Aug 5, 2004 | 05:12 PM
Anyone?
Old Aug 5, 2004 | 05:22 PM
I'd look at www.nelsonperformance.com
I'm not positive but I think they're seeing from 35-50 extra hp with the tune on a 6.0, depending on how aggressive it is. Its a whole new pcm (computer) and he'll send you a tuned one and you pop it in then send your stock one back to him
