UPD/Nitrous Nozzle?
Old Oct 27, 2003 | 02:29 PM
mudz5.3's Avatar
Question UPD/Nitrous Nozzle?
Has anyone tried to put a nozzle into a UPD? Wanting a clear UPD with a single nozzle kit for my truck.
Old Oct 27, 2003 | 04:38 PM
O3GMC's Avatar
12 Second Club
I haven't done it, but it should work fine......just drill the hole somewhere close to the t/b where you can get the nut on the other side of the nozzle - the only thing I might worry about is how the fuel effects the glue holding it together. btw - which n2o kit are you running?
Old Oct 27, 2003 | 06:48 PM
mudz5.3's Avatar
Default n20
I figured it would be ok to do, just wondering if anyone has tried it or not. I am not using one at the moment, since n20 is illegal up here. I plan on getting one eventually. Just a 100-300 shot adjustable using the bottom shot since I am stock. Also wanting to go to a 6.0 eventually, but too many things need to happen first. I am gonna go with NX though since I have experience using there products when I lived in Houston and I like there products as well.
Old Oct 27, 2003 | 07:24 PM
what about a dry shot? where'd you put the nozzle then?
Old Oct 27, 2003 | 07:34 PM
RED2K's Avatar
in front of the MAFS crazy
Old Oct 27, 2003 | 07:55 PM
GREGGO's Avatar
DON'T use a wet shot on a clear UPD tube. ONLY the black tubes are able to handle gasoline. I put mine about halfway down spraying in the direction of the T/B
Old Oct 27, 2003 | 09:06 PM
O3GMC's Avatar
12 Second Club
Are the clear UPD's a different material then the black ones or does it have to do with the glue? and Fast - which nitrous kit are you using, what kind of shot and have you had any problems?
Old Oct 27, 2003 | 09:16 PM
GREGGO's Avatar
That information came straight from UPD. I have a NOS wet system that I still haven't finished putting in. I've been a little gunshy since I blew the last engine. But I have a blower on the way, so I may not use it at all. Then again......
Old Oct 27, 2003 | 10:02 PM
no **** sherlock. THANK YOU CAPT. OBVIOUS! i was wondering if it would be best to put it close to the MAF or farther back....the UPD lid doesn't exactly have a whole lot of spots to easily place one
GXPJAY
Feb 13, 2022 08:15 AM
Silveradorst07
Dec 31, 2015 12:04 AM
Mr. Chainsaw
Oct 18, 2015 08:00 PM
custm2500
Aug 22, 2015 11:46 PM
