up date on a 6.0 search also need some help
Old Feb 4, 2009 | 12:49 PM
Michael Halo's Avatar
Default up date on a 6.0 search also need some help
i found a ls2 engine from a 06 trial blazer ss with 6,000 miles for $1,900 complet is it a easy swap from a 4.8 to a ls2?
also i found a lq9 for $800 but it was from a burned truck so the intake is gone whats the best deal? don't have much money lol
Old Feb 4, 2009 | 03:23 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
I'd go with the LQ9 and leave the rest for mods.
Old Feb 4, 2009 | 03:53 PM
nighthawk08's Avatar
i think 06 trailblazers had 58x reluctor wheel so that would make it more difficult to swap for you. But easy for me where's this at?
Old Feb 4, 2009 | 03:55 PM
Coban's Avatar
LQ9 would be cheaper if you are planning on swapping over all your accessories and intake. I would open up the motor and see if anything in the top end needs to be replaced too.
The LS2 will require some harness extensions due to different sensor locations. If you can spare the extra cost, this is the way I would go.
Old Feb 4, 2009 | 04:00 PM
Low_LSX's Avatar
It was difficult before but not anymore since LINGENFELTER makes this now "TRG-001 58X TO 24X CRANK SENSOR TRIGGER OR RELUCTOR WHEEL CONVERSION MODULE"
Old Feb 4, 2009 | 04:59 PM
but that just adds more cost to the swap. its still difficult and involved besides that module.
Old Feb 4, 2009 | 06:19 PM
well i'm buying the lq9 thats for sure but will my intake and ather crap from a 4.8 bolt on to the lq9 lol... and whats the best way to get the most out of it befor i swap it out?
Old Feb 4, 2009 | 06:38 PM
Low_LSX's Avatar
but that just adds more cost to the swap. its still difficult and involved besides that module.well i'm buying the lq9 thats for sure but will my intake and ather crap from a 4.8 bolt on to the lq9 lol... and whats the best way to get the most out of it befor i swap it out?
Well thats why I said LQ9.
Yes everything is the same. Spray some gas on it lol before you do the swap.
Old Feb 4, 2009 | 08:41 PM
is the lq9 injectors the same as a 4.8 and is the throttel body 75mm or 80mm i think on a 4.8 is 75mm
Old Feb 4, 2009 | 09:54 PM
budhayes3's Avatar
PT's Slowest Truck
Injectors and throttle body are the same...the throttle body is either 75 or 78mm...I've heard it called both...
