Twin turbo 5.3 do I need a better ecu or will the stock one work ?
Old Jan 15, 2024 | 08:57 PM
antneeomeger's Avatar
Registered User
Default Twin turbo 5.3 do I need a better ecu or will the stock one work ?
Precision 62mm turbos
Brian tooley stage 2 turbo cam
Summit Racing™ Coated Forged Pistons SUM-17401C
AEM Electronics Boost Control Solenoid Kits 30-2400
Old Jan 15, 2024 | 10:18 PM
FFDP's Avatar
The stock computer can do a lot. Just depends on what computer you are using and what operating system.
The stock calibration obviously won't work, it will have to be tuned by you with all the correct data put into the calibration to function correctly.
People can make 700-800+ horsepower on a stock computer no problem.
Old Jan 15, 2024 | 10:53 PM
arthursc2's Avatar
Concerning P59 and 0411-
Some of the ECUs have hard limits for things like rev limiter and injector sizes
I do not know which ones are which, and who is who- but these hard limits may make it hard to make the power you want, or achieve smooth idle on gigantic injectors
Some ECUs can do E85 and 3 bar MAP sensors. Some cannot. Some can do idle control of a manual throttle body and some cannot
I don't know if any of them can be directly attached to a boost solenoid. You might be able to fudge things around in some of the nitrous tables- or play with some of the I/O for things you may not be using. But I don't know if any of them have code written for direct control of a boost solenoid
Half-bred
Sep 7, 2010 09:13 PM
slowlsx
Oct 3, 2008 10:07 AM
wastedrubber
Mar 10, 2008 09:34 AM
04sierracanada
May 1, 2007 09:33 AM
