turning over with radix
Old Jul 8, 2004 | 01:30 PM
Mr. Sandog's Avatar
Well okay, that makes sense. To me, there is a subtle difference between 'most people agree' and 'it is recommended'....if it's recommended, I'd like to know who's doing the recommending. I didn't see the install sheet for the Radix so I thought perhaps it was on there, but after asking, I guess not.
WaitintoDrag, I hope you get your issue resolved.
Old Jul 8, 2004 | 04:27 PM
yeary03SS's Avatar
Is your inline fuel pump working correctly?
Old Jul 8, 2004 | 06:58 PM
retsell's Avatar
check your fuel pressure, watch for it to bleed off. If it falls off quickly (very quickly) then you need to pull the FPR and check the O-rings. If it falls off somewhat fast (back to zero after 30 min or so) then replace the FPR and the o-rings. Earlier revision FPR had a problem with the diaphram leaking and bleeding the pressure off into the vacum system which would cause a hard start situation if you do not let the fuel system pressure up before starting it.
Old Jul 8, 2004 | 07:47 PM
Flyer's Avatar
I was thinking the same thing retsell.
Here's another test .. instead of going out and hitting the starter, turn the key to the On position and wait 3 seconds, then turn the key off and then start it like you normally do. What this will do is pressurize the fuel system to around what it should be. Now that it's pressurized, that will eliminate that from being part of the problem if it still does the same thing. If that fixes it .. I would replace the fuel pressure regulator. The dealership should be able to sell it in a kit for around 100 bucks.
Old Jul 8, 2004 | 08:18 PM
WaitinToDrag's Avatar
thanks guys. i'll check that out later!
and while i have your attention....check out the thread of mine about my SES light.
and i just went to get some food...I HAVE NO 1st & 4TH GEAR!!! WTF!?!?
Old Jul 8, 2004 | 09:32 PM
yeary03SS's Avatar
Sounds like a bad tune. Are you using the one that came with the kit?
Old Jul 8, 2004 | 10:20 PM
yes i have the superchips tune. planning on new heads, pulley, and nelson tune next week...unless i have to fork out for a tranny
Old Jul 9, 2004 | 12:23 AM
Flyer's Avatar
Do you have a non stock converter ?
What code is it throwing ?
Old Jul 9, 2004 | 12:26 AM
stock converter. dont have antying to read the codes. takin it to a buddy at an autoshop in the morn and let him hook the diagnostic up to it
Old Jul 9, 2004 | 12:49 AM
Flyer's Avatar
DO that ... hget the code and clear them and see if it straightens up.
