turning on E-fans on my 05 SS
Old May 19, 2005 | 10:45 AM
11SECSS's Avatar
10 Second Club
Default turning on E-fans on my 05 SS
Was wondering how to turn on my fans with the truck not running ,for when I go to the track to help cool it off. Was wondering if someone sells a kit like SLP does for our F-bodys.
Old May 19, 2005 | 09:50 PM
SnakeOiler's Avatar
Run a wire from the 12+ constant (battery power) through a switch and then splice into the positive wire going to the fan motor (the motor is already grounded). . . . switch on. . . . .switch off.
Though, I think most people would probably run the power through a relay and energize the relay with the switch.
Old May 20, 2005 | 09:46 AM
11SECSS's Avatar
10 Second Club
not looking to do it that way would like a clean look like the SLP fan kit for the camaro that way I could control it better .
Old May 20, 2005 | 09:53 AM
tooquick2beslo's Avatar
Thats the only way to do it.
Bitch.
J/k.
Old May 20, 2005 | 12:18 PM
litreddevil's Avatar
Banned
pull off the fuse cover under the hood get a relay and run ever thing under that cover and put a water proof switch on the fuse box cover(like on the side or on back close to fire wall)everthing can be put in that black box lot of extra room in their.
Old May 20, 2005 | 08:01 PM
SnakeOiler's Avatar
Originally Posted by 11SECSS
not looking to do it that way...
How else would you do it?
...would like a clean look like the SLP fan kit for the camaro...
It will be as clean as you make it
...that way I could control it better .
Please elaborate. How much more control do you want?
Old May 20, 2005 | 09:01 PM
officialfoxracer2006's Avatar
i want e fans for my 99 silverado, will it help a lot?
Old May 21, 2005 | 08:23 AM
11SECSS's Avatar
10 Second Club
Bitch.
J/k.
I'm going to make it look factory if I can and try to control it like the camaros kit does .....
dsbodley
Nov 14, 2015 09:46 PM
smok'nZ
Oct 6, 2015 01:14 PM
turbo6c3
Oct 5, 2015 06:11 PM
old motorhead
Sep 29, 2015 08:22 PM
trevorh1
Sep 27, 2015 08:47 PM
