Turbo setups for the trucks
Old Jun 4, 2003 | 05:00 PM
XLR8NSS's Avatar
Adkoonerstrator
Default Turbo setups for the trucks
Is anyone REALLY working on a setup for us? I remember seeing some stuff about kits in the works but, still nothing??
Old Jun 4, 2003 | 05:08 PM
parish8's Avatar
single digit dreamer
Default Re: Turbo setups for the trucks
if they dont have one when i am ready i think i will try and get a set of turbo headers from one of the fbody kits and 2 turbos and an intercooeler from the duramax. make the rest i guess.
Old Jun 4, 2003 | 05:21 PM
XLR8NSS's Avatar
Adkoonerstrator
Yeah for a while I was thinking about making a kit but, I just don't have the space right now to do it. I was thinking of a big single(T76 or T88) with a front crossover pipe setup. Electric fans make for alot of space up front to work with. The turbo would be on the passenger side since there is more room over there for a downpipe.(probably be better for 4wd trucks also). I was thinking of putting an intercooler in front of the engine crossmember at an upward angle in between the frame rails. I think the ATI kit may be setup like that but, have never seen the intercooler for it. I'll have to take a look at the Duramax intercooler setup. What's it look like??
Your idea sounds interesting. I think you'd probably have to fab some manifolds up though, maybe logs.
A twin kit would be nice but, alot of extra work to get setup right.
Old Jun 4, 2003 | 07:49 PM
parish8's Avatar
i know it will be a huge project but it seems to me with all that space between the radiator and motor it can be done. i dont know if i want single or twin but i do know i want to size it for 1200+hp, i dont care about a slow spool, i will just run a reversed staged nitrous out of the hole , i want some 9's!!!!
Old Jun 4, 2003 | 08:51 PM
I think one large turbo with an adjustable wastegate with a huge liquid(ice water)cooled intercooler would be the easiest way to big horepower numbers especially if you are going to spray to.The liquid reservoir could be located in the cab or bed for quick easy refills,build some custom longtube headers running forward,join the two header collectors into a wye turbo manifold in front of the oil pan,pipe the boosted air thru a heatexchanger just before the stock throttlebody location.Run your wastegate under passenger side exhaust header and run a 4" exhaust system just tell everyone it's a Duramax.Fabricate a combination spacer oversize throttlebody adaptor to locate nitrous nozzle or nozzles just behind the throttlebody.I think you could get 800-1000hp depending on boost(12 street 22 track?) like that with a well built engine with forged internals.You would have to do it without a massair sensor(to restrictive)so you might consider a stand alone engine management system.
Old Jun 4, 2003 | 09:09 PM
With 1000hp and 6000lbs Parish8 you might have the heaviest 10second 135mph truck on the planet.
Old Jun 4, 2003 | 09:11 PM
XLR8NSS's Avatar
Adkoonerstrator
Yes, at the power levels parish is talking about a stand alone computer would be a necessity.
PSJ is going to be testing one that shouldn't cost $3000 like a FAST system(properly setup). Hopefully he will have good news about it.
Slammed96
Jul 27, 2015 07:22 AM
oharajo
Jul 18, 2015 09:24 PM
black6spdz
Jul 16, 2015 01:32 AM
03sierraslt
Jul 11, 2015 02:47 PM
