Tuning for different year trucks
Old Jun 30, 2002 | 01:54 AM
BigTex's Avatar
Default Tuning for different year trucks
I noticed the autotap log posted by BigKID. The timing given out by that 2002 truck is very high. Using LS1 edit, I took the time to open several differnet truck files and compared them to my 99 PCM. Here is what I have come up with so far:
On my 99, in the upper rpms, my stock timing is anywhere from 8*-14* (depends on the MAF flow). On a 00 model, timing is similar, but is about 1* to 2* higher. My 99 hypertech moves timing up to the 22* range. Tuning for a stock 00 6-liter showed timing near 20*.
The autotap log for that 2002 year model showed timing @ 28* slowly dropping to ~ 25*. I assume it has hypertech installed, but that is several points higher than my hypertech gives out. These are good values. On LS1 cars, getting timing in the upper 20s is the goal.
I'm going to raise my timing some more and check the results.
Richard
Old Jun 30, 2002 | 09:26 AM
BigKID's Avatar
Default Re: Tuning for different year trucks
Yes that truck did have the Hypertech tunning installed. Logs from my 2000 show a max of 27* bur normally run in the 24-25* range at WOT.
SLOPONY
20
Oct 18, 2016 06:05 AM
cams 98 silverado
Jul 31, 2015 07:36 AM
black6spdz
Jul 16, 2015 01:32 AM
4B11T
Jul 13, 2015 03:48 PM
