Truck wouldnt start all day. Plugs were WET WET!
Old Jan 19, 2005 | 11:01 PM
Default Truck wouldnt start all day. Plugs were WET WET!
Lately its been getting harder and harder to start my truck, and today finaly it wouldnt start at all. After over an hour of cranking on it with jumper cables hooked up to it i pulled the plugs to see if they were fouled. Sure enough they were almost dripping wet. This is my 4th set of plugs in less than 10k miles. They seem to last about 2k miles or so. I know its still got really low timing and running pig rich for the N2O, but damn.
I went ahead and changed the plugs and it fired right up, but idled really rough. I put the logger on it and took it for a ride and my A/F gauge never fluctuated off red. It stayed in open loop, in the red. So after 3 miles i looked at the logs and B1S1 was reading a steady .2 and B2S1 was a steady .980. The misfire code said only one of the O2's were working and the A/F was being set by just one of them. Out of curiosity i looked into the trouble code logs from the past 2 months and they said the same. Only one is working. I just thought it was a normal missfire code from the cam and never looked into it before. I guess i should have. LOL
So now its time to change the O2's. I'll do it in the morning and post back up it it runs better again.
How much are they anyway?
Old Jan 19, 2005 | 11:55 PM
GREGGO's Avatar
Front 02's. You should be able to get them from the dealer for $78 each. That's the wholesale price. That's what I get them for.
Old Jan 20, 2005 | 08:02 AM
called around all the auto parts stores and the lowest i found for Bosch was $71. One Tire Warehouse place has them for only $62, but the wont be in for a couple days.
Old Jan 20, 2005 | 09:24 AM
BigKID's Avatar
You do not want a Bosch, get Delco replacements. And dont let the Autoparts guy tell you that the Bosch and Delco are the same just because they have the same number.
Old Jan 20, 2005 | 10:03 AM
FILE's Avatar
How do the Denso compare to the stock ones?
Old Jan 20, 2005 | 10:14 AM
onyx's Avatar
14 Second Truck Club
are the stock sensors Delco?
Old Jan 20, 2005 | 11:57 AM
Stock ones are ACDelco, and are $89 each after a 10% NAPA discount and 5% military discount. And i had to go to 2 different dealers to get both because each dealer only keeps one in stock. BS!!!!!!!!!!!!!!!
But $190 later its up and running again. Maybe i should take it easy on the race fuel.
Old Jan 20, 2005 | 01:49 PM
i went with the leaded proof bosch for 52 dollars a piece so i can run race gas if i want.
Old Jan 20, 2005 | 02:15 PM
Really, do you have a P/N for those? I wonder if they will work ok.
Old Jan 20, 2005 | 09:48 PM
Black Blown 02's Avatar
When I got new ones, I shopped around and got ACDelco's online for $52 a piece.
