Truck Won't Start
Old Feb 26, 2005 | 02:30 PM
DeanHensler's Avatar
Default Truck Won't Start
I've got a 93 Chevy K1500. I haven't started it for around 3 months. Last weekend I power washed the engine bay. I went out to start it today (after thinking a week would be enough time to dry everything out) and it wont start.
It turns over, but doesn't start. I'm guessing the engine isn't getting fire. What is the first thing I should check, and how should I check it?
Old Feb 26, 2005 | 03:21 PM
brandont454's Avatar
pull the distrubutor cap off (2 screws)
is there moisture in there?
if yes get some compressed air and blow the cap and rotor out.
let it sit with the cap off for a while to get any other moisture out.
replace cap. truck should now start.
Old Feb 26, 2005 | 03:38 PM
Toook the distributor cap off, bone dry in there... Also took both fuel lines off the TBI unit and turned the motor over, no fuel came out of the lines. Also took the #1 spark plug wire and put a test light in it.. Turned the motor over and the light didn't blink. I can't do a spark plug test because I don't have another set of hands to turn the key while I'm in the enging bay... So I don't know if its a fuel issue or a spark issue. Any other suggestions?
wrb002
Aug 31, 2015 12:00 PM
chevyl33
Aug 24, 2015 08:21 AM
cams 98 silverado
Jul 31, 2015 07:36 AM
InsaneDomestics
Jul 27, 2015 02:42 PM
black6spdz
Jul 16, 2015 01:32 AM
