Truck won't start
Truck won't start
I have a 01 silverado. It won't turn over at all. I turn the key on and when I got to start I can hear the relay click and nothing at the starter. We banged on and everything. I want to know if it the starter. I need to know ASAP.
12 Second Club
your battery doesnt have enough cranking amps to turn the motor.
get a new one and see. or just have O'rielly's or autocrap check it out for you.
you can take them just the battery and they can test it.
i had the same probablem with mine. wound up replacing the alternator and battery.
also if you try and jump start it. and it starts its not your starter IMO. if you do get it started take it up to one of the places that i mentioned and have them check it out.
good luck
good luck
cams 98 silverado
07-31-2015 07:36 AM
InsaneDomestics
07-27-2015 02:42 PM
