Truck won't idle after cam swap!!
Old Sep 6, 2009 | 05:50 PM
00Silv4.8's Avatar
its not gonna "relearn". It will kinda adaptive to idle but driveability is due to tuning. Dont ***** foot around it. Bottom line it needs a good tune and a dyno tune if you want driveability and WOT all at once.
Old Sep 6, 2009 | 07:26 PM
krambo's Avatar
Amen. Do not look for "Band-Aids" here. You need your tune worked over.
Old Sep 6, 2009 | 11:23 PM
00Silv4.8's Avatar
hence why I gave up tuning Nic found **** I NEVER woulda thought of
Old Sep 7, 2009 | 02:53 AM
jeff46614's Avatar
I understand that it needs to be retuned. I just wanted to get it to run long enough to bring it up to operating temp, so I could check coolant level ok before my tuner comes. He should be here in about 2 weeks, I'll keep my fingers and toes crossed. Once I get her running, I will try and post a clip or at least a pic of her. Went with the all stock look and had the stock rims widened on the rear($280). Running 285/60/16 on rear and 245/70/16 on front. Thanks again for all your help!
Old Sep 7, 2009 | 04:51 AM
Spoolin's Avatar
GFYS and STFU
You can bring it up to operating temp with no adverse effects, just don't go driving around like a wild man thinking your truck will run fine. I'm in the same boat you are in right now + a few other mods. It barely idles if it's up to temp other than that it doesn't wanna do anything, I can warm her up and driver her around my parking lot and across the street for some gas but other than that I'm waiting for a proper tune.
Old Sep 7, 2009 | 08:24 AM
budhayes3's Avatar
PT's Slowest Truck
Two foot it until you get it tuned, I wouldn't go permanently drilling the throttle blade for a temporary fix, just my .02
Old Sep 7, 2009 | 08:56 AM
jeff46614's Avatar
So here's a question for all. When I changed the cam the first time from stock to the ZO6 cam, I had very little issues with the cam swap (of course it ran better after being retuned), why now? Does it have something to do with the duration or LSA changing?? I know I got the timing right. I even went as far as buying a top dead center tool and checked it over and over with a LS1 tech mechanic buddy of mine before I took the top gear off for the oil pump and chain swap. Then unplugged the coil packs, pulled the fuel pump relay and turned the engine over a few time listening for valve to piston noise or anything. Nothing, sounded fine! Besides that ticking at the initial start that went away after a few minutes (lifters pumping up with oil) everything went fine.
Old Sep 7, 2009 | 12:45 PM
sureshot's Avatar
The Z06 cam is alot closer to stock specs. Your new cam is much more aggressive-have it tuned for the cam and it will be fine.
black6spdz
Jul 16, 2015 01:32 AM
chevy1224
Jul 13, 2015 07:50 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
Aboss
Jul 9, 2015 10:28 AM
GreyChevy
Jul 7, 2015 08:57 PM
