truck will not start, please help!
Old Oct 16, 2010 | 11:09 PM
jg53's Avatar
Default truck will not start, please help!
i know this is in the wrong section but im trying to get some help here
this evening i installed my tune from nelson, after install i go to start my truck
truck throws the crank/cam relearn which i have a scanner for but what i dont know what its doing is throwing a service theft deterrent system.
to this i have no clue, can anyone help me out here?
Old Oct 16, 2010 | 11:34 PM
budhayes3's Avatar
PT's Slowest Truck
Sounds like you need the security relearn, I thought that the tune came with instructions on how to do that...I'll see if I can dig it up. Moving this to a different section also...
Old Oct 16, 2010 | 11:37 PM
jg53's Avatar
yeah i figured it was going to get moved, i figured i would get more help in here than i would in another section. so thats why i posted it. but please if you could help me out here getting those instructions that would be greatly appreciated!
Old Oct 16, 2010 | 11:41 PM
budhayes3's Avatar
PT's Slowest Truck
Yea, that's why I moved it here instead of the tuning section, figured that you'd get more hits
Anyway, I copied and pasted this off of Nelson's website:
1. Insert key, attempt to start the vehicle and leave the key in the ON position.
In some vehicles, the Battery and Security light will blink for several seconds, and then shut off. Then the Security light will then remain ON. Leave the ignition ON until the Security light goes OFF. This will take more than 5 mins.
2. When the Security light goes OFF, turn the ignition to the OFF position.
Leave ignition OFF for 20 Seconds.
3. Attempt to start the vehicle again and leave the key in the ON position.
4. Turn the ignition to the OFF position for 20 Seconds.
5. Attempt to start the vehicle again and leave the key in the ON position.
6. Once this entire procedure has been completed (three times) your vehicle will start on the fourth attempt.
Note: Some vehicles perform the relearn in a different sequence. You may notice your security light, battery light and abs light will alternate. Once the security light is left out of the sequence that is considered one step. Repeat the procedure two more times and on the fourth time your vehicle will start.
IIRC, the first time I swapped in a tuned PCM, I attempted to start it and left the key on for 11 min, then repeated that twice, and on the 4th attempt cranked and started the truck
Old Oct 16, 2010 | 11:47 PM
jg53's Avatar
thank you for doing some research for me! im going to go attempt that right now.
Old Oct 17, 2010 | 12:20 AM
budhayes3's Avatar
PT's Slowest Truck
Glad to help, hope it works!
wrb002
Aug 31, 2015 12:00 PM
chevyl33
Aug 24, 2015 08:21 AM
cams 98 silverado
Jul 31, 2015 07:36 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
black6spdz
Jul 16, 2015 01:32 AM
