Truck Tires/ Towing Q's...
Registered User
I really don't know much about towing, but here goes...
I need new tires on my 2wd taHOE. OEM are 235-75-15's.
I need C-load tires is that right for towing?
Cheapest and the bestest? I plan to sell the truck in the spring for a newer one.
How about:
General, Continental and Scorpian?
Pulling open trailer and Firebird.
How about:
As long as you get a light truck tire, you will be fine. But you don't HAVE to get an LT to tow. With the weight your towing (~4500# right?) you can get just about anything as long as it is the right size. If your gonna sell next year, get the cheapest thing you can find.
Greg
Greg
No major complaint about those tires. But I just got a set of off brand 255/70/15's for my DDDodge <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> for $308 mounted/balanced and out the door. They ride just fine. I would just hate to see you spend ~$500 for a set of tires and get ride of it next year. Here are some tires for you: http://www.tirerack.com/tires/Compar...al&manufacture r=General
Greg
<small>[ October 16, 2002, 04:38 PM: Message edited by: Fast4.8 ]</small>
Greg
Get the C-loads. This is what I could find on "letter"load ratings. http://www.oktire.sk.ca/loadrating.shtml
Greg
Greg
GTO Forum Director
Two things you need to look at with a tire for towing;
1) What is it's maximum load capacity and at what pressure in order to obtain that load capacity.
2) Load Range. You specified "C" which I'd deem questionable when towing a trailer that's around 5,000lbs. Not that the "C" couldn't handle it, just that it'd be pushing it. I'd definetely look into "D" range tires.
All the C, D, and E ranges signify is how many plys the tire is. D is an 8 ply tire and E is a 10 ply tire. While this may not seem important, it can be. More plys equal a stiffer tire. A stiffer tire will prohibit "swaying" of the sidewall under load.
As an example, the HD came with Firestone 245/75-16 load range "E" HD tires. They had a maximum load of 3,035lbs at 60psi and they were a 10 ply tire. When I removed them in favor of my bigger BFG A/T's (285/75-16's), I gained nearly 300 extra pounds of load capacity (up to 3,300lbs each) which was obtained at a little more friendly 45psi, but I did drop a range down to "D" (8 ply tire).
Ya gotta trade off which you want. Losing a load range wasn't as important to me since I don't have a 5th wheel/gooseneck setup. And I tow regularly with mine!
