truck running horrible(rich?) after ASM header install
Originally Posted by gonzo 6.0
I bet you may have a miss due to a cracked sparkplug.You need to get it welded up and then isolate which cyl.
I would avoid it.not likely to be the death of it,would be best to having it run right.How about instead of buying a whole new set, just install your old plugs one side at a time,do the passenger side first.Actually when i cracked one it was on the drivers side due to the tight steering shaft clearence.
when i was putting them back in, i for some reason remember hearing a crack, but i never thought that i cracked the plug untill you mentioned it.
iam gonna change that one out and see what happens. thanks
Originally Posted by vtodd82
do you think it could be simply because of the o2 sensors are sensing an excessive amount of oxygen becaue they are so close to the outside environment???
ok guys, i just checked my spark plugs.....they were all EXTREMELY black with that carbon ****. i put the plugs back in, and called on star to read my engine light code after that.
it was p0171. after a little reading, i found that it has something to do with the engine being lean. ??? i dont get that, i would have thought it was running rich, but iam no expert. what do you guys think??
thanks
thanks
