Truck is pinging, wondering if MAF could be reason
Old Jan 9, 2004 | 01:48 AM
abbo7's Avatar
Default Truck is pinging, wondering if MAF could be reason
I have a 4.8L with a K&N FIPK and a GRANATELLI MASS AIR FLOW SENSOR. Under heavy acceleration it is pinging. I think it is because of the Granatelli, what do you guys think. I am going to put the stocker back in and see if it helps. I have heard the Granatelli could make the truck run lean. It is calibrated for a stock intake so that could make it even worse.
Old Jan 9, 2004 | 07:47 AM
Black Blown 02's Avatar
Thats probably it. As far as I know, all the guys on here that are making big power are doing it through the stock maf.
Old Jan 9, 2004 | 09:31 AM
tooquick2beslo's Avatar
If you want you can always run higher octane gas. I have a Granatelli MAF and mine runs just fine. I also have HPIII also. I am running Nitrous so I have it set to 87 octane on the programmer but I also run 93 octane in my truck at all times cause I never know when Im going to spray.
Old Jan 9, 2004 | 11:07 AM
Texas Terminator's Avatar
11 Second Club
use the MAF as a wheel chock!
Old Jan 9, 2004 | 11:56 AM
Try changing your fuel filter first,I did that and it cured the problem.
Old Jan 9, 2004 | 12:41 PM
BlownChevy's Avatar
blownerator
25 Year Member
Me too. I have seen motors ping to DEATH on these things.
Old Jan 9, 2004 | 01:36 PM
abbo7's Avatar
Yeah it looks like the MAF is going back to stock, I will be doing it tonight. I would say it could be the fuel filter but the truck only has 10,800 miles on it. I will tell you guys what I find out.
ferrellrooster
Mar 6, 2025 03:22 PM
wrb002
Aug 31, 2015 12:00 PM
Slammed96
Jul 27, 2015 07:22 AM
ferrellrooster
Jul 17, 2015 07:07 AM
black6spdz
Jul 16, 2015 01:32 AM
