Truck owners with odometer MPG readout, a question..
Old May 9, 2005 | 11:05 PM
glock35ipsc's Avatar
Question Truck owners with odometer MPG readout, a question..
I have always had good luck using the MPG readout option on the odometer. It seems to be fairly consistant, in that it usually reads about .5 to .75 MPG higher than what I am actually getting.
Now that I have the Whipple on, should I expect it to remain as consistant? I assume that it uses a vacuum signal to calculate it's reading. Will the new combination of vacuum and boost mess with it's little brain and give me screwy readings?
Old May 10, 2005 | 12:28 AM
Yelo's Avatar
I'd bet that it uses the TPS, crank sensor, and l-trims to calculate MPG......a vacuum signal seems WAY too old-school
Old May 10, 2005 | 06:24 AM
KySilverado's Avatar
Mine has never been correct. Always about 1mpg high. Before and after charger install.
Old May 10, 2005 | 07:00 AM
Mine has always been off too, but still consistantly off. I can pretty much count on it after correcting for the usual difference. So yours is at least still somewhat consistant after the supercharger install?
Old May 10, 2005 | 07:26 AM
Yes, or was when I first installed the charger. Haven't looked at it in awhile. I just calculate actual.
Old May 10, 2005 | 03:02 PM
14 Second Truck Club
Mine was pretty acurate with and without the supercharger, usually only about .2 mpg off. Problem is it says 12.5 mpg!
Noah Burns
Oct 5, 2015 06:46 AM
wrb002
Aug 31, 2015 12:00 PM
black6spdz
Jul 16, 2015 01:32 AM
abey15
Jul 13, 2015 02:20 PM
350SS
Jul 11, 2015 12:34 PM
