Is the truck intake really that bad? Discussion.
Old Apr 22, 2004 | 12:00 PM
2003blue5.7's Avatar
Originally Posted by vanillagorilla
That sounds REALLY interesting. Will they be running an article on that? I've read in another mag. that the LSX intake is an awesome design. It also allows pretty extensive porting, which would help bigger displacement applications and high reving engines.
Does anyone actually know the real runner lengths for any of these manifolds? If we have that, we can use one of those runner length equations to see if the truck manifold is actually adequate above a given RPM.
I feel that any intake where you gain hp, and don't lose any tq is a win-win situation. But if you lose tq and gain hp, you lose, especially with a heavy truck. Rarely will you gain in both areas though. Just my thoughts.
I have a ls1 book that says ls1 & ls6 intakes have a runner of 262mm and the truck one is 263mm
Old Apr 22, 2004 | 12:59 PM
BigTex's Avatar
Like I said earlier, runner length isn't the issue. I think the open plenum design of the LS1/LS6/Holley/LSX will provide better distribution and all out flow compared to the center inlet of the trucks intake.
Here is something that hasn't been mentioned before:
How does the intakes's actual runner path effects engine power? The truck intake has air starting from the top then going around the bottom then into the cylinder head. The LS16X intakes have the air starting from the open center then going over the top then down into the head. Depending on the flow path of the intake, incoming air is going to merge with a different area of the heads port surface. Which intake design places the air on the best path to take advantage of the cylinder head's port shape and valve location?
I think the intake that best compliments the cylinder heads design would be the best choice.
Old Apr 22, 2004 | 02:44 PM
01Blackerado's Avatar
Big tex has done it again
Old Apr 22, 2004 | 06:29 PM
StupidFast's Avatar
That is what I was trying to get at. You should think about what camshaft or heads you will have before planning on the swap. The LS6 intake is not always the best choice. It was starting to sound like bolting up a LS6 intake would gain huge amounts of power through the entire rpm range.
I was wrong about the runner length, which is why I started the thread. To learn. The air path is different and that may be the only thing that really seperates the two.
I don't think you will find a magic truck cam that will make 400 rwhp at 5500 rpms.
I didn't mean that you can make all the power in the world with this intake, with just a cam. I was just thinking that with a small camshaft (212/218) and some mild heads the truck intake would be better (for trucks). The 10hp up top, is not worth the 10ftlbs throughout the low and midrange.
Old Apr 22, 2004 | 08:44 PM
one03sierra's Avatar
Formerly one92rs
Talking
man i am glad someone answered all this. just when i was going to think about a swap to. heck farmtruc is using a truck intake on his ls1 and is spinning it to 6300 rpm's and it is still making good power.
Old Apr 23, 2004 | 10:09 PM
GMChasLS1's Avatar
Farmtruc has the truck intake, and I have the LS6 intake. I'm pretty sure both trucks are matched for HP. His is a 2001 LS1 and mine is a 2002 LS1, same heads, cam ect. Maybe he will chime in on this.
TA63
Mar 29, 2016 04:38 PM
wrb002
Aug 31, 2015 12:00 PM
Slammed96
Jul 27, 2015 07:22 AM
black6spdz
Jul 16, 2015 01:32 AM
jrplz
Jul 9, 2015 12:07 AM
