Truck idling high too high and trans not shifting right
Old Nov 27, 2009 | 06:42 PM
waterdog's Avatar
Black99Silverado, Did you figure anything out yet?
Old Jan 31, 2010 | 02:10 AM
did you ever find the cause of this? Mines doing the same thing now...
Old May 13, 2011 | 06:40 PM
Darknight-4's Avatar
Mine has been doing this off and on for the past couple years. It just recently got a lot more often, almost all the time. Replaced the IAC and it seemed to be all better...until today when it happened again. Killed the engine, started back up and it was fine again.
This is some really annoying stuff, any ideas?
sprayed carb cleaner all of the place with no apparent vacuum leaks.
Throttle body and MAF sensor are freshly cleaned too.
Old May 15, 2011 | 03:04 PM
budhayes3's Avatar
PT's Slowest Truck
As well as cleaning the MAF, I'd check all of the wires going to the throttle body (IAC, TPS) and make sure that none are brittle or broken, and that all of the terminals are making good contact. If you have access to a scan tool, view the data and see what is out of spec when the problem occurs
Old May 15, 2011 | 04:39 PM
Thanks for the help, will try to get a buddy to log it when it is messing up.
ferrellrooster
Mar 6, 2025 03:22 PM
black6spdz
Jul 16, 2015 01:32 AM
lxcoupe
Jul 14, 2015 10:14 PM
jrplz
Jul 9, 2015 12:07 AM
GreyChevy
Jul 7, 2015 08:57 PM
