Truck idles like crap/dies when fuel level is less than 1/4 tank, fuel pump?
Old Sep 22, 2010 | 08:28 AM
BlackGMC's Avatar
Resident Retard
Default Truck idles like crap/dies when fuel level is less than 1/4 tank, fuel pump?
I have had this annoying problem for about a year now. When ever the fuel level gets below 1/4 tank the truck starts having some idle issues... It will surge and sometimes die... But it only does it when it is below a 1/4 tank... I am starting to think it is my fuel pump. Another reason i think my fuel pump may be weak, is my VE values in the 95-100kpa range are above 110%, i think i peaks at 115%... I have 31# 8.1L injectors and my IDC is about 74%.... I have put a mechanical fuel pressure gauge on it before, the fuel pressure was good, except i had about 4-5 PSI drop at WOT...
I only have issues at idle when it is below 1/4 tank, once off idle it is the exact same.... My LTFTs stay about the same the no matter what fuel level i am at... The only other thing i can think of is there might be some emmissions test that occurs below 1/4 tank...
Any ideas?
Old Sep 22, 2010 | 09:04 AM
banker099's Avatar
disable all emissions related codes and see if that solves your problem, what is your fuel pressure when the problems occur?
Old Sep 25, 2010 | 11:50 AM
ricoc's Avatar
shouldn't fuel pressure go up when the throttle opens?
Old Sep 25, 2010 | 11:58 AM
BlackGMC's Avatar
Resident Retard
I got a new fuel pump on the way. So hopefully that should ruleout the pump and make my ve table a little more realistic
Old Sep 25, 2010 | 04:37 PM
dlt76028's Avatar
You going to drop the tank or lift the bed? I'll give you a hand either way.
Old Sep 25, 2010 | 09:11 PM
BlackGMC's Avatar
Resident Retard
Actually i have read about people just sliding it backwards some... Sure if it comes in this week, i am planning on swapping it Friday on my day off or the weekend.. If you wanna help that would be great.
Old Sep 25, 2010 | 09:16 PM
jpodell's Avatar
I've had the same problem with the work truck. Originally it started when 3/4 of the tank had been used. Just before the pump went out I could only use half a tank before it acted up. Good luck.
Old Sep 25, 2010 | 09:21 PM
BlackGMC's Avatar
Resident Retard
ya mine is starting to get worse... WOT is fine, but my VE table looks rather retarded in the 95kpa+ ranges...
Old Sep 25, 2010 | 09:27 PM
dlt76028's Avatar
That might work with the tires off, otherwise the bed will hit the tires.
Old Sep 25, 2010 | 09:29 PM
BlackGMC's Avatar
Resident Retard
lol, i did not even think about the tires.... So isn't it just a couple of bolts and disconnecting the rear harness and the bed comes off?
