Trans Temp
Old Oct 2, 2002 | 09:48 PM
1TRUESS's Avatar
Default Trans Temp
Would like to install some gauges. Trans temp, Air/fuel, fuel pressure. Any help would be great. Don't know whrer to hook up or how, would like to use Autometer gauges. 02 5.3 4L60.
Old Oct 2, 2002 | 10:03 PM
badpewter-z's Avatar
LS1TECH Sponsor
Default Re: Trans Temp
well for the trans temp i'd say escalade/denali/hd cluster which already has the gauge
the others im not a 100% sure on
Old Oct 2, 2002 | 10:11 PM
1TRUESS's Avatar
Is that a direct plug in or will I have to take it in for programming?
Old Oct 2, 2002 | 10:18 PM
CHAGO's Avatar
the cluster is a direct plug in;
you would just have to worry about the mileage transfer
Old Oct 2, 2002 | 10:45 PM
Brandon Boomhauer's Avatar
how about this idea
fuel pressure on the crossover between the fuel rails with a wet kit hooked up toit
how would one do that??
Old Oct 3, 2002 | 03:47 AM
1TRUESS's Avatar
I have thought about that. running a 100psi gauge up threw my cowl in the hood so I could see it from the cab.
Old Oct 3, 2002 | 10:14 AM
99GMC Can's Avatar
I think an electric oil sending unit should work without having to pay lots cause it says FUEL
Old Oct 3, 2002 | 10:26 AM
BigTex's Avatar
I agree with the cluster swap for the trans temp gauge. I have the denali cluster and it works great. It is plug and play and it will reset your mileage back to 0. Its a 10 minute swap. It also gives you a 120 MPH speedo. The escalade cluster will be more $$$ but gives you chrome rings around the gauges.
ferrellrooster
Mar 6, 2025 03:22 PM
brandon6.0
Aug 19, 2015 07:48 AM
GRRR65GTO
Aug 17, 2015 11:33 PM
Matt C.
Aug 1, 2015 01:25 PM
Nimoryan
Jul 5, 2015 03:50 PM
