Trans Flush.. Dex 3/6/?
Old Jan 11, 2009 | 02:48 AM
laynlow77's Avatar
Default Trans Flush.. Dex 3/6/?
my manual says 6. many people have told me that 3 is fine. ive also heard there is an additive that turns the 3 into 6. thoughts?
Old Jan 11, 2009 | 09:11 AM
DBVille's Avatar
If the manual says VI, why would you go with III? Save $30-$60? On a transmission that will cost $1,000-$2,500 to repair/replace? I believe GM recommends VI on all trucks 2006 and later, and says VI is a direct replacement for III in earlier models. And, it can be mixed with VI.
GM does not have an additive to convert III to VI.
Old Jan 11, 2009 | 09:33 AM
Red04Silverado's Avatar
Put VI in and dont look back.
Old Jan 11, 2009 | 12:40 PM
budhayes3's Avatar
PT's Slowest Truck
You can always go up (III to VI), but you shouldn't go back (VI to III), if the manual says VI, go with VI
Old Jan 11, 2009 | 12:53 PM
2005 Silverado's Avatar
SPAM HUNTER
100%
Dustin
Old Jan 11, 2009 | 01:15 PM
Fireman31's Avatar
Dex VI is synthetic and better in almost everyway when compared to Dex III......
Old Jan 12, 2009 | 12:13 AM
laynlow77's Avatar
bump. im doing this tomorrow
is there a reason that the 06 needs 6, but 05 uses 3. are the internals different?
Old Jan 12, 2009 | 06:18 AM
DBVille's Avatar
The fluid came out to support a 6 speed tranny, I believe. However, the VI is better all around, and is recommended for all III applications. It is used as OEM fill on all GM autos.
When I change my '05 fluid, it will be with VI.
Old Jan 13, 2009 | 01:22 AM
negativeswitches's Avatar
6 will help make your tranny outlast your motor
Old Jan 13, 2009 | 02:23 AM
laynlow77's Avatar
well, i went down and saw my trans guy. he assured me that the 3 and 6 are nearly the same but the six has a couple different additives in it. i wound up going with 3 and the additive he told me to put in. the gm tech also told me that there isnt much difference.
this is what i did last time as well and i havent had any problems yet....
