trans cooler and 02 sensor??
Old Mar 5, 2014 | 06:30 PM
bizle's Avatar
Default trans cooler and 02 sensor??
Just had a couple of quick questions for you guys?
Planning on installing my new pacesetter long tubes and ory pipe this weekend on my 03 ecsb 5.3 2wd.
Did anyone have to extend their 02 sensor wiring?
Next question
Also i will be installing my new circle d stall at the same time 3-3200
My truck came with the factory tow package and has a external trans cooler.
Should i upgrade to a bigger cooler?
Street truck no towing
Old Mar 5, 2014 | 08:12 PM
bizle's Avatar
Also what size and style clamps are you guys using
For your connection from header to y pipe?
Should i use the clamps that came with the y or buy band clamps? If so what size
Old Mar 6, 2014 | 09:14 PM
bizle's Avatar
Looks like from everything i have read the 02 sensor wiring will reach.
Im going to just use the clamps that came with the new y pipe.
So im down to my trans cooler question?
Old Mar 6, 2014 | 09:24 PM
BlackGMC's Avatar
Resident Retard
I have installed several sets of headers on various trucks. I never had to extend the o2 sensor harness.
For the cooler if you have a way to monitor the trans temps i would just watch them for a few days/weeks to see if it gets tooo hot. Or just install a tru cool 40k. That is what i run.
Old Mar 6, 2014 | 10:30 PM
1ownerCHEVY's Avatar
When I put my stall in I ran it with no cooler and my temps were between 170-190. I put in a Hayden 679 and now im at 145-170. It helps alot, especially here in phoenix. Will come in handy when it starts to get in the triple digits.
As said earlier o2s should be fine, I didnt have to extend mine.
Old Mar 6, 2014 | 11:10 PM
bizle's Avatar
Perfect thanks guys
ullose272
Aug 5, 2016 02:05 PM
GRRR65GTO
Aug 17, 2015 11:33 PM
1slwgto
Aug 16, 2015 06:40 PM
Ls3silverado
Jul 31, 2015 04:22 PM
ferrellrooster
Jul 17, 2015 07:07 AM
