Tranny valve question. Fast reply please....
Old Oct 11, 2004 | 05:32 PM
slowprocess's Avatar
Exclamation Tranny valve question. Fast reply please....
Transmission shop called today and said they may have left a valve out of my tranny. They said it was easy to look for and easy to install. All I have to do is remove the pan and see if the valve is there or not. They are sending me a valve overnight, but does anybody have a clue what valve they are talking about? How hard is it to put in? He said it was easy, but I really have no clue, so it looks like I'm going to have to take it to another tranny shop so they can get it put it right. I don't think I'm capable. Thanks and please reply if you have any idea what is going on here.
Old Oct 11, 2004 | 05:40 PM
one03sierra's Avatar
Formerly one92rs
Talking
wow the only valve i can think of is the accumulater valve without pulling the control valve.
Old Oct 11, 2004 | 05:46 PM
yeary03SS's Avatar
The only valves visible when the pan is removed is the boost valve and then the pistons and springs that work as valves in the valve body, but then all you see to those are the plugs on the end or solenoids. Do you have all gears and no problems with the tranny? I couldn't imagine it running correctly with a valve left out.
Old Oct 11, 2004 | 05:48 PM
The tranny just got here. I haven't installed it yet, and it doesn't even have any fluid in it yet. I paid alot for this tranny too!!!!!!
Old Oct 11, 2004 | 05:53 PM
agreif's Avatar
Yean, I'm with 02, the accum...although it could be the manual valve, but I'm pretty sure you would be going nowhere without that as it connects the shift linkage.
Andrew
Old Oct 11, 2004 | 06:05 PM
Flyer's Avatar
It could be a number of valves. The valve body has 6 I think, and a couple of others. There's also one in the pump.
If you get a picture of the valve and the valve body with the pan off I might can help you out.
Old Oct 11, 2004 | 06:52 PM
agreif's Avatar
Try this, page three shows the manual valve I was talking about. I know this can be seen with the pan off, but I think you need to drop the VB to get it off due to the way the linkage connects to it.
http://james.jaguar.net/agreif/001.PDF
Andrew
Old Oct 12, 2004 | 11:39 AM
I found out today it is the 3-2 downshift valve? He said it would take like a minute to find and put in. Anybody know. Thanks
Texas5.3_1251
Mar 5, 2016 08:10 PM
dantheman1540
Sep 18, 2015 03:03 AM
lxcoupe
Sep 11, 2015 03:17 PM
cousblake11
Sep 9, 2015 06:52 PM
mayko
Sep 7, 2015 12:24 PM
