Tranny took a crap last night
Old Jan 7, 2004 | 05:14 PM
  #41
ThunderZ28's Avatar
12 Second Club
ok ive been reading this post and i had the same problem almost. after installing my vig 2800 i threw up an ses light. missfire code. caused by the torque converter having to much slippage. this was corrected with edit and now everything is fine. no ses light.
allthough my truck never went into limp mode. but i do have a built tranny. so maybe that had something to do with it.
Old Jan 7, 2004 | 05:39 PM
  #42
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Hmmm...so I guess any torque converter will cause this, not just anything above 3000.
What code did you throw Thunder and how did you correct it with Edit?
How hard was it to learn Edit? Did you just go by trial and error?
Old Jan 7, 2004 | 05:48 PM
  #43
ThunderZ28's Avatar
12 Second Club
been getting allen from nelson performance to fix it and then comparing files im still learning.
Old Jan 8, 2004 | 02:41 AM
  #44
Hit Man X's Avatar
Originally Posted by Chingon
Yea, I have the B&M cooler, Transgo shift kit and both billet servos...I just need to get rid of TM now...or maybe some of it...I bet my tranny will if I take out all of TM...
TM? That **** is ALL gone from my tranny...
Old Jan 8, 2004 | 02:42 AM
  #45
Hit Man X's Avatar
Misfire probably due to the small diameter confusin the computer... small diameter = less rotational mass.
Old Jan 8, 2004 | 08:29 AM
  #46
onyx's Avatar
14 Second Truck Club
oh.... well that sounds a little more reassuring flyer.... about what percentage should be taken out?.... 80.. 90...?
Old Jan 8, 2004 | 11:29 AM
  #47
Flyer's Avatar
All if you have the transgo kit that came with a video.
Old Jan 8, 2004 | 11:24 PM
  #48
Under "Transmission Diagnostics"
"Test Parameters"
What is your "Torque Converter slip" Normal slip and fail RPM set at?
Old Jan 9, 2004 | 08:34 PM
  #49
"Test Parameters"
TTT. Can you tell me what these numbers are set at 01Thunder?
Old Jan 10, 2004 | 12:51 AM
  #50
ThunderZ28's Avatar
12 Second Club
hey sorry chingon havnt looked at this post since you posted that. i will check and let you know.
