Traction Problems
before my tt3000 install - no wheel spin unless torque braking
after tt3k install - slight wheelspin and then takeoff (on the street)
after predator - wheelspin for about 7-10 feet
(this is weird) at the track - no traction whatsoever, even easing it down led to wheel spin - put spare tire back in bed and regained a little traction but not nearly enough to floor it off the line. Never went in water box, tried many methods of launching and slight burnouts (started just be spinning them over a few times to clean them off and ended up getting aggrivated and roasting them, which suprizingly helped the launch on street tires)
now on the street w/50 shot = like I'm on ice
Once I get ahold of some et streets or drag radials, its track time again.
Sticky tires and good weight transfer will definately hook your truck you'd probably have trouble spinning the Drag Radials enough to keep the truck from boging.I know that's hard for you to beleive but it's the truth,especially with 3.42 gears.The Caltracs are traction bars they prevent wheel hop,not wheel spin.
get yourself a set of caltrac's and a set of m/t et streets. That will solve your problem. I get 1.7 60' times with caltrac's and 28x11.5 et's. drag radials are nice but et's are more worth the money imo.
Originally Posted by onyx_silverado
a properly tuned PCM should correct these traction problems... correct?
i mean.... it should be able to set the lock and all that on the TC's right?
ohhh... duh.... geez... but by using TQM, not losing TQM.... i want to still be able to use this truck as a DD... cuz reading all this about it feeling "loose" has got me concerned because Tucson is nothing but stop and go traffic... its rediculous...
