Traction bars
Old May 6, 2003 | 05:52 PM
blemoine02's Avatar
Default Re: Traction bars
that lateral trac bar looks great and all but will it work for a lower truck woith a flip kit on it because i need a traction bar for my truck with the flip kit and the one from AIM will it work if its set for a 98 truck arnt the rears the same it should work right
Old May 7, 2003 | 12:23 PM
blemoine02's Avatar
bump
Old May 7, 2003 | 01:49 PM
Pro Stock John's Avatar
Registered User
Would old skool Lakewood traction bars work on a 2wd 99 Hoe Ken?
I get wheelhop with my truck 'ba bap' and I'd like to cure it.
Old May 7, 2003 | 05:29 PM
oxidizr's Avatar
Moderator / Sponsor
They should ...
Old May 7, 2003 | 07:09 PM
blemoine02's Avatar
does anyone know if the aim traction bars for a 98 old school truck work for a 00 chevy truck arnt the rear ends the same if they are exactly the same they should work right
Old May 7, 2003 | 09:21 PM
Yes they are the same and I don't see why they would not work.
Wouldn't mind seeing a close up of it before I would purchase.Curious what the front mounting hardware look's like.
Old May 7, 2003 | 09:49 PM
blemoine02's Avatar
here is the pic ok if not here is the link it looks just like all the others out there and my truck has a 5 7 drop too he said it will work on a 5 7 for a 98 but i cant see there is any dffrent between body styles rear end con figuration aim traction bar
Old May 7, 2003 | 10:20 PM
I saw this picture in the original post but you can't tell what type of connection the front is.
The only difference I have noticed in the 88-98 and the 99-02 rear suspension is 88-98 has 4 leaf springs(well my 94' did anyway)and the 99-up has 3.I have also tried to install a shock extender off of a 99 onto a 97 and it was a different design(can not remember what the problem was)
I say go for it,if all else fails find you a pre-99 owner and resale them.You might loss a couple of dollars but at least you can tell me if they worked or not
If you don't want to risk it give me about 2 weeks when I come off of vacation I'll give them a try.
Old May 7, 2003 | 10:36 PM
blemoine02's Avatar
cool if you try beforew i do please email me please or im me ok thanks ill try if not i will make a custom bracket to work and what are some good rear sway bars look will it work if i but some air bags on the rear for trackion too and i need it to lift the rear up some its too soft
Vortec350ss
Jan 12, 2016 10:36 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
Alco
Oct 4, 2015 06:58 AM
carid
Oct 1, 2015 09:22 AM
WICK3DxGATA
Sep 24, 2015 06:56 PM
