F-body 2600 converter--will it work?
Old May 7, 2003 | 11:23 AM
Scream's Avatar
MOOBIES Moderator
Default F-body 2600 converter--will it work?
A friend of mine is getting a higher stall converter to replace the 2600 stall (not sure of the brand) in her T/A. Would it be worth the trouble to swap out the factory truck converter for a 2600? Will it work?
Thanks!
Old May 7, 2003 | 12:13 PM
Default Re: F-body 2600 converter--will it work?
The convertor will fit will your truck.It will probably stall about 2200 rpm in the truck.With the cost of an install in mind you might want to contact the manufacturer of the convertor to see what they charge to restall the convertor before you install it in your truck.
Old May 7, 2003 | 01:37 PM
sleepersilverado's Avatar
wate a min. i thought it would stall higher than 2600 because the truck is heavier. Also wont it get hotter because it is smaller in diameter. But i have always been under the impression thet f-bod converters in trucks stall higher.
Old May 7, 2003 | 09:22 PM
BigTex's Avatar
I think it will stall a little less that 2600, more like 2400. This id due to the cars having more torque than the trucks. In that split second when it flashes, more torque will make it flash higher.
Old May 7, 2003 | 10:42 PM
When they take the convertor out of the F-body find out who the manufacturer is.Call and find out what they charge for a restall.Some manufacturers will do free restalls for the original owner and others charge about $100.Have your friend sent it back and you pay the charges.That way you won't be dissappointed with the convertor and be out more than one install.
Stainless Works
Apr 10, 2016 04:34 PM
Stainless Works
Aug 4, 2015 12:56 PM
Matt331
Jul 26, 2015 09:40 PM
Ketis
Jul 23, 2015 12:37 PM
atxlt
Jul 20, 2015 11:06 PM
