Track video of 2bseen's 11.83
Old May 4, 2005 | 12:25 AM
If you dont mind sharing, what kind of nitrous setup are you running, and how much were you spraying on those runs. How far do you plan on going with the nitrous, I'm sure there's more to be desired. I plan on being at MMP the 21st, hopefully we'll be fortunate enough to have some good track prep.
Old May 4, 2005 | 12:33 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I know a 408 and mpg are an oxymoron but what kind of mileage are you getting from it?
Old May 4, 2005 | 06:32 AM
cablebandit's Avatar
9 Second Club
nice runs Tony. it leaves good! What is your gearing and tire size?
Old May 4, 2005 | 06:52 AM
gomer's Avatar
11 Second Club
He's running a NX wet kit on a window switch and WOT switch as the first stage. It is jetted for 50hp and comes on at 2800rpm and turns off at 6,000. His second stage is a "home made" dry kit jetted for 75hp that he brings in manually with a pushbutton when the truck shifts into second gear.
The wet is going to 75hp next, but he's going to bring it in later (3400rpm) so the truck won't spin so bad and won't shut off until 6,300 (6400shift) also, as soon as it gets rolling good, he'll hit it with the dry that will be jetted at 100hp. He wants an 11.50 out of the truck and we'll see how close that gets him before we spray it any harder.
Btw, he's running factory front and rear diffs with 4.10 gears and a 29inch tall tire on 20 inch wheels. Each wheel and tire weighs 96lbs
Old May 4, 2005 | 08:35 AM
2bseen's Avatar
11 Second Truck Club
My mpg is the same I am getting 13.0 and that is what the 6.0 was doing also. I was running the 42# injectors with that motor also.
Old May 4, 2005 | 05:30 PM
That thing is an 03' SS? The paint threw me off.
Old May 8, 2005 | 12:34 AM
Default go for 10s
Put the damn 200 shot nozzle on it man and get some drag radials and lighter wheels. Just kidding good luck on the 11.50. I'll be there to cheer you on or calm you down which ever ya need. Your truck is bad ***. I'll still bet ya a I can catch ya in the 1/4 brother.
CYA later
Old May 8, 2005 | 12:40 PM
Nice!..... i like the color
AdaMax
May 16, 2016 11:35 PM
bearden86
26
Nov 15, 2015 03:58 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
Wolftrk99
Oct 2, 2015 08:17 AM
carid
Oct 1, 2015 09:22 AM
