Tr6 problems tune or??
Old May 23, 2015 | 09:38 AM
evand's Avatar
Default Tr6 problems tune or??
I did some work on my truck new long tubes, full exhaust, headgaskets, I installed a fresh set of tr6 iridium plugs.
Double checked everything no loose plug wires leaks or problems. Not tuned yet.
I am getting missfires at idle. every cylinder missfire.
I want a colder plug going to run a little nitrous. Is this tune related or ???
Old May 23, 2015 | 11:02 AM
03sierraslt's Avatar
What exact plugs did you install and what gap?
Old May 23, 2015 | 11:36 AM
evand's Avatar
Ngk 3689 called ngk they said it's a tr6 iridium
Old May 23, 2015 | 11:47 AM
What was the gap?
Old May 23, 2015 | 11:51 AM
evand's Avatar
they were 0.04 from ngk I left the like that.
Old May 23, 2015 | 11:56 AM
MrHorsepowerLSx's Avatar
11 Second Club
Not much of a gap there if that reading you posted is actually .004, are you sure that you didn't typo the gap numbers.... Should look like this .040 +/-
Old May 23, 2015 | 02:58 PM
I don't think I would run a fine wire plug with nitrous. Something like a BR7EFS would be my choice.
Old May 24, 2015 | 08:14 AM
evand's Avatar
Double checked everything.
at idle= slight missfire
while driving absolutely no missfired while on the gas.
No check engine light Shows on scanner
Old May 24, 2015 | 10:34 AM
Byrdman11's Avatar
Sound like vacuum leak.
Y
Old May 24, 2015 | 10:35 AM
Byrdman11's Avatar
Look at long tern fuel trim at idle
ferrellrooster
Mar 6, 2025 03:22 PM
mr03silverado
Jun 26, 2016 06:05 AM
shawn96gmc
May 17, 2016 04:15 PM
pittman
Jan 19, 2016 07:06 AM
lxcoupe
Jul 14, 2015 10:14 PM
