Tr 220 or 224
I have heard the 224 is hard to tune for the 4.8l. I cant afford a dyno tune so nelson will be doing it. Should i go with it or the 220. I drive the truck daily and i dont want to hurt drivability too bad. What do you guys think? Also should i run dual valve springs? How many ppl have actually had a 918 break on them?
Thanks,
Derek
Thanks,
Derek
Thanks,
Derek
Thanks,
Derek
Your 5 spd with 4.10's. Thats alot of low end. I say 224. if you are just wanting an off the shelf cma grind. May want to look into running a small split. Ask nelson what he can do with a mailorder and get as close as possible to that. I would go big with the cam and save up a few months for the dyno tune. If you get the smaller cam just because of a tune you will wish you got the bigger one in a month or so afte5r.
