Tr 220 or 224
Old May 9, 2007 | 11:44 AM
virgils4.85spd's Avatar
Default Tr 220 or 224
I have heard the 224 is hard to tune for the 4.8l. I cant afford a dyno tune so nelson will be doing it. Should i go with it or the 220. I drive the truck daily and i dont want to hurt drivability too bad. What do you guys think? Also should i run dual valve springs? How many ppl have actually had a 918 break on them?
Thanks,
Derek
Old May 9, 2007 | 12:48 PM
brodystruck's Avatar
I'd go with the 220 in a 4.8L...
Old May 9, 2007 | 12:51 PM
UnrthdxDream's Avatar
i stay even smaller than that personally...
Old May 9, 2007 | 01:06 PM
Thanks,
Derek
I've seen three sets of 918s broken in less then a week. One truck had a 220 cam and dropped a valve and fuked the engine, the other one was a friends ss with a 228 cam we were just giving a check up on the springs and one of them was broken, we ordered another set and changed them before it was too late and after using it for a day or two, we checked it again and found another spring broken.
Old May 10, 2007 | 11:23 AM
Default Ok so ill prob go dual springs .....
but the cam... i have heard good results with the tr 220 112. Anyone have any other suggestions?
Thanks,
Derek
Old May 10, 2007 | 11:30 AM
onebadrubi's Avatar
Your 5 spd with 4.10's. Thats alot of low end. I say 224. if you are just wanting an off the shelf cma grind. May want to look into running a small split. Ask nelson what he can do with a mailorder and get as close as possible to that. I would go big with the cam and save up a few months for the dyno tune. If you get the smaller cam just because of a tune you will wish you got the bigger one in a month or so afte5r.
Old May 10, 2007 | 12:58 PM
Default i also dont want
too bad of gas mileage. Right now i drive 45 mi one way to work. That is kind of a factor too but 4 deg shouldnt make that much diff should it?
Derek
Old May 10, 2007 | 03:07 PM
99/5.3w/hips's Avatar
I would go with the 220 just because 224 is a lot for a 4.8 DD
Old May 10, 2007 | 05:33 PM
Cuerva's Avatar
11 Second Truck Club
Old May 10, 2007 | 06:05 PM
2001si3rr@'s Avatar
I wouldn't go over 220 for your daily driver!
