Tq specs
Old Aug 18, 2005 | 08:15 AM
white1's Avatar
Default Tq specs
I need to find out what to torque some new heads to. I tried a search, but I'm at work, and the boss was coming. So I'll check back later.
Old Aug 18, 2005 | 08:25 AM
Fogle07's Avatar
Tighten the M11 cylinder head bolts a first pass in sequence to 30 Nm (22 ft. lbs.).
Tighten the M11 cylinder head bolts a second pass in sequence to 90 degrees using the J36660-A.
Tighten the M11 cylinder head bolts (1,2,3,4,5,6,7,8) to 90 degrees and the M11 cylinder head bolts (9 and 10) to 50 degrees a final pass in sequence to using the J36660-A.
Tighten the M8 cylinder head bolts (11,12,13,14,15) to 30 Nm (22 ft. lbs.) . Begin with the center bolt (11) and alternating side-to-side, work outward tightening all of the bolts.
heres a picture
http://i6.photobucket.com/albums/y22...04/cylhead.gif
Old Aug 18, 2005 | 09:10 AM
BigKID's Avatar
Assuming you are using new stock bolts, use Fogle's procedure above. If you are using ARP head bolts, follow their instructions/torque specs.
Old Aug 18, 2005 | 09:35 AM
white1's Avatar
I dont guess I can just torque them then? Where can I find one of those degree things?
Old Aug 18, 2005 | 10:00 AM
BigKID's Avatar
It is easiest to ust a marker and put a line on the bolts. If you put a horizontal line(-), 90* will put the line straight vertical(|). 50* will then put it diagonal(/).
Here is an excellent writeup on a head swap. http://www.ls1howto.com/index.php?article=3
Jake75
Oct 2, 2015 02:28 PM
Wolftrk99
Oct 2, 2015 08:17 AM
jscherbs
Sep 30, 2015 07:54 AM
okie454ss
Sep 22, 2015 07:39 AM
chvy=power
Sep 8, 2015 11:06 AM
