towing?
Old Mar 21, 2011 | 06:43 PM
dlt76028's Avatar
it will more then likely self destruct.... naw the 4.10s will help alot since you probably have 90ftlbs of TQ with that cam and stock converter lol... but address the rear suspension.
Old Mar 21, 2011 | 07:56 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
With the already shitty low end of the 4.8 being exacerbated by that cam you will probably have better luck running it in 3rd the whole time. If you ever get tired of that cam let me know, Ill pull it for you
Old Mar 21, 2011 | 09:02 PM
gs7793's Avatar
Originally Posted by Lloyd-TX
Should tow OK, but since when does a 21' boat, motor, trailer, etc. only weigh 1200 lbs!?!
NOT!
well the boat and motor itself is 1200, its a light go fast bass boat that barely sits down in the water lol, so 1200 plus the trailer
hahaha im gonna call you to tow me when it self destructs!!! lol but yeah, gimme a link to the helper bags i need! haha
exacerbated? say what? hahaha....i have thought about doing a cam swap to a higher compression cam with a lower lsa since the turbo plans for the truck are out the window, i'll let you know if i swap it out
Old Mar 21, 2011 | 09:49 PM
swift700's Avatar
I have the Firestone Sport-Rites. Easy to install and hold their air. I use them for a 900lb tongue weight on my trailer. They give a solid feel overall, too.
Old Mar 22, 2011 | 01:06 AM
gs7793's Avatar
^i was just looking at those
i was also just looking at these though, theyre a little cheaper...
http://www.stylintrucks.com/parts/ai...0583_2165.aspx
Old Mar 22, 2011 | 08:19 AM
bullygoat's Avatar
Once you build you actual truck, they're more expensive than the firestones from auto anything.
calsdad
Jun 14, 2023 11:07 PM
AdaMax
May 16, 2016 11:35 PM
cheyenne383
Nov 13, 2015 09:24 AM
SWINGRRRR
Sep 3, 2015 07:49 PM
