Tow Truck Help
Old Dec 4, 2002 | 07:44 PM
Mike@Vengeance's Avatar
LS1TECH Sponsor
Default Tow Truck Help
I am getting a tow vechicle. Want to know the differece between the 1500HD crew cab and the 2500HDcrew cab besides the body.
Thanks guys
Old Dec 4, 2002 | 08:15 PM
GREGGO's Avatar
Default Re: Tow Truck Help
frame, suspension, and tranny. I may be wrong, but I think the 1500HD has the 5.3 and the 2500HD starts with the 6.0.
Old Dec 4, 2002 | 08:50 PM
The 1500HD comes with the 6.0 in it.
Old Dec 4, 2002 | 10:23 PM
Banned
different gearing and tranny maybe?
Old Dec 5, 2002 | 09:09 AM
G McCall's Avatar
The ride will be a big big! difference. I have a 2002 2500 HD 4X4 extended cab (duramax). The 2500 is a 3/4 ton truck that rides much rougher than any 1/2 ton chevy I have had, even my 98 extended cab 1500 Z71. However, if your pulling much over 6000 lbs you will like the 3/4 ton handling.
FYI my 98 1500 extended cab Z71 with tow package pulled my car hauler and car a total of 6,000 lbs + - just fine. I got the new 2500 for my travel trailer.
<small>[ December 05, 2002, 09:11 AM: Message edited by: G McCall ]</small>
Old Dec 5, 2002 | 04:41 PM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
1500HD is really a ¾-ton truck (8600gvw).
2500HD is really a 1-ton truck (9200gvw).
The frame on the 2500HD is stronger & taller (that's why they sit ~2 taller).
1500HD only comes with 6.0 & 4L80E automatic.
2500HD can get:
· 6.0 with 4L80E or 5-speed manual
· 8.1 big block with Allison auto or 6-speed man.
· 6.6 Duramax turbo diesel with Allison or 6-speed.
1500HD has a 9.5" 14-bolt Semi-floating rear end (3.73 or 4.10).
2500HD with 6.0 has a 10.5" 14-bolt Full-floating rear end (4.10 only).
2500HD with 8.1 or Dmax has a 11.5" Full-floater (big ****).
2500HD has a couple more leaf springs out back, thus rougher ride while unloaded.
2500HD has slightly larger brakes.
Wheels & tires are rated the same.
2500HD is a little heavier, thus cutting into overall GVWR, (and slower <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> ).
1500HD is shorter, (easier for the ladies to get in <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> ).
Other than that, they are basically the same. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Dec 6, 2002 | 09:30 PM
LS1TECH Sponsor
Thanks guys for all your help I think I will be going with the 2500HD to get the maximum for my money.
wrb002
Aug 31, 2015 12:00 PM
Suburban2500
Jul 19, 2015 04:50 PM
black6spdz
Jul 16, 2015 01:32 AM
My72olds
Jul 10, 2015 11:26 AM
