Torn Between Some Cams
Old Oct 4, 2005 | 12:42 AM
yellowchev02's Avatar
14 Second Truck Club
Default Torn Between Some Cams
Ok guys I have done my homework on some cams,checking out the cam page and other sites, and I still have a few questions. The potential cams are: Vinci High Performance
"047"(210/218 .531/.531 114)
"062"(210/218 .551/.551 112 )
GM
"hot cam"(219/228 .525/.525 112)
Questions which cam will lope the hardest,kinda dumb question but it will be a factor,and which cam could I get away with without a stall?
(4.8 auto),current mods: pacesetter lts,ory,cutout,cia. I would like to also spray after the Cam so the best cam for nitrous is also a factor.
Any info and opinions much needed
Thanks guys matt
Old Oct 4, 2005 | 01:46 AM
Okie5.3's Avatar
bottom to top order of "lopes hardest". top to bottom order of driveability without stall. not sure which would be the best for a nitrous application. the 062 does build alot of cylinder pressure which may not necessarily be a good thing to spray on top of.
Old Oct 4, 2005 | 02:25 AM
Mr. Sandog's Avatar
With all of those cams you're pushing it with a stock converter. The third one is way too big for a 4.8L, you'll be limping along until about 3000 RPM's or maybe more.
To get your goal of 'lope' you'll need a small LSA, so the second one (with a 112 LSA) is your best choice to get some decent power, with a lope, while still being driveable.
Old Oct 4, 2005 | 05:16 AM
tdrumm's Avatar
The 062 is an awesome cam!
Old Oct 4, 2005 | 12:37 PM
Deckhand's Avatar
I have the hotcam and its a decent cam, lopes hard, make good power. However, with the stock coverter I would NOT recommend it. I have a 3000 stall, so for me, there was no loss of low end.
Old Oct 4, 2005 | 12:47 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I would go with the 062 if oyu plan on staying with the stock converter but if you want performance get a damn converter and get the hot cam and have fun leaving two black marks across any unsuspecting intersection.
Old Oct 4, 2005 | 01:18 PM
1slow01Z71's Avatar
Off topic but what kind of electric cutout do you have and how do you like it?
Old Oct 4, 2005 | 01:58 PM
el_cabby's Avatar
well i have the 047 under my bed and waiting to install , wheneve that is. ill let u know if i ever get it installed.
Old Oct 4, 2005 | 08:19 PM
It is the QTP and I like it alot good quality and reliable so far
Old Oct 4, 2005 | 08:22 PM
Just wanted to thank everyone for their input it helps a ton during the decision process. So it seems the 062 would be a good pick does anyone have a sound clip of that cam?
