Top mount supercharger, check this out>>>
Old Oct 25, 2002 | 01:47 PM
L82gofast's Avatar
Default Re: Top mount supercharger, check this out>>>
I don't know but it sure looks sweet. Lingenfelter knows his stuff......and proud of it too.$$$$
Old Oct 25, 2002 | 02:31 PM
red53gmc's Avatar
LPE H2 Hummer 6.0L SC Package
500 Horsepower
New top mount intercooled supercharger
Package includes:
Engine disassembly & inspection
LPE custom cylinder head porting and polishing
Three angle valve job, set spring heights, assemble heads
Porting and polishing of intake manifold
Balanced rotating assembly
Pin fit pistons and connecting rods
LPE custom hydraulic roller camshaft
Valve springs, titanium retainers, valve locks
JE Forged pistons & heavy duty piston pins
HD Rod and main bearings
Gaskets, spark plugs, oil and fluids
Magnacharger supercharger package
Properly sized injectors
Yank custom torque converter
Professional installation, testing and calibration
B&B Tri Flow stainless cat back exhaust
2 year/24,000 mile warranty
Package price $17,600.00
Options to package
HD automatic transmission rebuild 2,195.00
Old Oct 25, 2002 | 02:58 PM
really slow truck's Avatar
those h2's are fugly though <img border="0" alt="[barf]" title="" src="graemlins/gr_barf.gif" />
looks much better in this article, only problem is u better hope magnacharger sells pulley upgrades for it because they were kind enough to set stock at an insane 4.5PSI
http://www.off-road.com/chevy/reviews/magnacharger/
Old Oct 25, 2002 | 03:54 PM
L82gofast's Avatar
Your right about them being ugly, bigtime. It says its intercooled but I don't see any intercooler or how they are cooling the discharge with this setup. Interesting....
Old Oct 25, 2002 | 04:30 PM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
See, what I'm thinking is I can rotate that tube that is running into the back of the blower, turn it straight up, cut a hole in the hood and have this popping up out of the hood...
<img src="http://store.summitracing.com/global/images/prod/large/wnd-7222.jpg" alt=" - " />
It would fuggin rule! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
Old Oct 25, 2002 | 04:33 PM
Thats Magnachargers new S/C. Its a top mount Eaton roots 120. It is intercooled via air to water. Just like the great Ferd Spark. It is a damn good setup, but I just like ther rest of the Magnacharger owners will tell you, The kit is awesome, but you cant modify them. I wish i went with an ATI, but the reliability of the Eaton, and the great design of Magnacharger is what sucked me in.
J
Old Oct 25, 2002 | 05:24 PM
sleepersilverado's Avatar
i e-maild lingenfelter and they said a kit for are trucks would be out in dec. but did not know the price. i also asked them if it would work on a h/c setup. considering whipple told me i could not use theirs.
Old Oct 26, 2002 | 12:57 AM
Neil 6.0's Avatar
Default Top mount supercharger, check this out>>>
<img src="http://www.lingenfelter.com/Lingenfelter/Assets/product_images/images/8484wb.jpg" alt=" - " />
http://www.lingenfelter.com/pac6ltmagschum.asp
I wonder how well that manifold flows?
Old Oct 28, 2002 | 02:02 PM
yep, whipple is just covering there *** probably.
saying you CAN'T run a heads/cam setup with anything is kindof dumb lol. but you will for sure need larger injectors and a custom tune as maxmumboom said. No matter what type of supercharger you go with the heads/cam setup will only make it that much better if it is done correctly.
Old Oct 29, 2002 | 12:14 AM
Sleeper silverado:
I dont see why you cant do a head/cam setup with your Whipple. You will need larger injectors, but I dont se why it wouldnt work. I can be sur eyou will need to custom tune your ECM but thats the name of the game.
J
Stainless Works
Apr 10, 2016 04:34 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Stainless Works
Aug 4, 2015 12:56 PM
carid
Jul 24, 2015 05:00 AM
71ls2
Jul 20, 2015 11:53 PM
