Which tool which u guys recommend me to use??
Old Jan 5, 2009 | 04:10 PM
chevrolade's Avatar
2 bad i dont got the crane tool in front of me,i only have the first 2,ide order the crane tool,but more down time
Old Jan 5, 2009 | 04:30 PM
Mangled03gmc's Avatar
Baltimore Whore
There has got to be sombody in the HUGE stat of texas that will prob let you borrow it, if you ask really nice.. Hell a guy from md let me use his when I needed it.. Tex is just a teeeeeny bit bigger, with just a few more members then MD
Old Jan 5, 2009 | 05:18 PM
chevrolade's Avatar
Shoot ide pay someone to do it,but i live in a small azz town infested with mustangs,not too many lsx fans here to help.
Old Jan 5, 2009 | 07:38 PM
WorkTruc's Avatar
crane tool was a piece of cake to change 2 springs at a time
Old Jan 5, 2009 | 08:04 PM
2005 Silverado's Avatar
SPAM HUNTER
I have used B it kinda sucked until i found the sweet spot to grap the spring. (Top half and compress it all the way but some extra pressure was needed to remove the retainers at times.) But if i do it again i will be getting the crane tool which i have seen used before it rocks.
Dustin
Old Jan 7, 2009 | 06:25 AM
black4x4's Avatar
I used the homemade one when I did my spring no problem except it was slow. if I had a chioce out of all those I would use the crane one
Old Jan 7, 2009 | 07:43 AM
Doobie's Avatar
+1 for the Crane tool. Spring shoulder slots cut into press plate keep the tool centered over valve stem while leaving the spring locks free and clear for hassle free removal. Spring is held compressed while you have both hands free to remove/install locks.
Old Jan 7, 2009 | 09:12 AM
KLUG'S SS's Avatar
FormerVendor
The Crane tool may be the most expensive, but it is by far the best. Besides doing 2 springs at once, it pushes them straight down and holds them down so you don't physically have to. I've also used the one in the 2nd pic, and it works well but is very tedious to use. I don't like the JPR tool from Thunder Racing, it can slip sideways, doesn't press straight down on the spring (pushes at a slant) and won't get on the rear springs when used in the truck. IMO, the Crane tool was worth every penny
The one from Crane is worth every bit of what it costs!!! It makes it go so quick and easy. IMO, dollar for dollar the best engine type tool I have purchased.
Old Jan 7, 2009 | 10:17 AM
chevrolade's Avatar
just ordered the crane tool,should be here tomorrow,thanks guys,it should come in handy,i plan later down the road to upgrade to comp918's or better.
Old Jan 7, 2009 | 10:46 AM
KLUG'S SS's Avatar
FormerVendor
Good choice!
