Too much cam????
Old Feb 6, 2008 | 10:39 AM
  #21
hirdlej's Avatar
I think you're referring to the TrickFlow Stage 1 cam. If so, that's the one I was going to go with for my 6L build. It should provide ample power everywhere up until 6200 RPM's or so (which who needs to go higher than that anyways?). I was going to buy one of these cams when they were only $269.99 but now that the word is out that they're made by Lunati and put out great power they're up to $349.99. I wonder how smooth they idle. Also if Zippy is right about the LS6 springs, it would be the way to go on a budget.
Old Feb 6, 2008 | 02:23 PM
  #22
ap2002's Avatar
Originally Posted by BlackGMC
Who builds that cam? I am looking for something similar, but only one I found was by Comp Cams and it was a lower lift...
im pretty sure its a custom specd cam, call richard @ wcch, he'll custom grind you one for the same price
Old Feb 6, 2008 | 02:24 PM
  #23
BlackGMC's Avatar
Resident Retard
Thanks, when the time comes, I will call him!
Old Feb 6, 2008 | 03:42 PM
  #24
BLACKND's Avatar
I didn't pay attention to the lift specs listed. I had the one from Comp Cams.
Old Feb 6, 2008 | 04:00 PM
  #25
WFOsierra's Avatar
the cam i got was made by trick flow, from summit racing, 269.95
matching pushrods, 80.00
deff, going to get a stall but has to wait a lil bit. The truck is kinna a DD but kinna not. it sits around the garage untill the weekends or sometimes i drive it to work, Verry Rarely!!.
Is there ny Transmission upgrades i can do without having to pull it out?....
Also i gotta redo my exhaust when i get my headers on, Cant hardley tell it has a cam in it..lol..that kinna takes some of the fun out of it...lol...any exhaust suggestions?
Old Feb 6, 2008 | 04:03 PM
  #26
WFOsierra's Avatar
its idles good, has a lil shake to it ever now and then when it want to slobber a lil bit. as far as sound it sounds good, but i am going to have the exhaust redone when i get my new LT's on. After the cats come off all them dodge and ford guys should be able to tell if its cammin or not at a redlight...lol..
Old Feb 7, 2008 | 02:28 AM
  #27
Originally Posted by MeanZ71
I'm running a 2400 stall w/ a 222/224 and I tow light trailers, you'll be happy with the 2600
this is a great cam i just to run it on my old 5.3L set fully bolt-on with a 3400 stall and used it as DD all the time..........
Old Feb 7, 2008 | 12:05 PM
  #28
jakebdb56's Avatar
Ha, true. That overlap should get you a nice little lope. I wasn't expecting the HotCam to lope like it does, but I realized that it was a 9* difference it made sense. Anyways, looks like a good cam selection for a DD
Old Feb 7, 2008 | 04:09 PM
  #29
WFOsierra's Avatar
N e one knoe of a cheaper set of LT's for a 4x4 nnbs?
The supermaxx are the only ones i can find, The pacesetters will only fit the 2wd nnbs trucks. By the way the dynatech supermax LT's for nnbs 4x4 trucks will run about $900.00 n e were u can find them.....so n e suggestions?
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
