TOG headers or ASM headers
Old Jun 7, 2004 | 08:58 PM
TwoFast's Avatar
Default TOG headers or ASM headers
Which give you more power? Which sound better? Are the TOG headers mid length?
Old Jun 7, 2004 | 09:14 PM
Mn Avalanche's Avatar
Go with togs if yu want a easy install.My azsm lt were a mother@##$%^ to
install.The passenger side alone took hours,to install.But i think if yu are 2wd its alot easier.As far as power goes huge diffrence in torqe up to 4000 rpms.MY truck got quieter after header install .And tog headers are midlength headers..
Old Jun 7, 2004 | 09:53 PM
FILE's Avatar
Both will give you about the same power. I really like my ASM's but they could improve their coting
Old Jun 7, 2004 | 10:29 PM
Hit Man X's Avatar
Yeah, TOGs are considered midlengths but they are EVER so slightly shorter.
TOG build quality is considerably better than ASMs to me. Thicker flanges, thicker tubing, and a lifetime warranty.
Old Jun 7, 2004 | 10:50 PM
i just ordered a pair of the TOG's hope they work out great
Old Jun 8, 2004 | 11:59 AM
11 Second Club
I like the ASM's better, and they aren't hard to install. Driver side has no obstructions at all. Remove your intake tube and heat sheild below the evaporator, and the passenger goes in with out any problem. I ground off the tab on the steering shaft, but it wasn't needed. The Togs have a thicker flange, but the flange on the ASM's is pretty thick as well (more than enough).
Old Jun 8, 2004 | 12:01 PM
hink9's Avatar
where can you get togs headers, is the price similar to asm's long tubes would make more power, not enough to tell a difference between the two. im in that same delima also.
Old Jun 8, 2004 | 12:25 PM
MarineBlue03GMC's Avatar
Tech Fanatic
I love my ASM's. I havent had any problems with the coating and I think the build quality is excellent. The install wasnt especially easy but no where near as much work as my hotchkis springs and edelbrocks.
The torque and hp increase was definitely noticeable throughout the whole rpm range.
Old Jun 8, 2004 | 04:26 PM
mwalls54's Avatar
Need More N2O Mod
i just ordered a set of asm so in a few days i will let ya know how the install goes
Velocity1
Oct 12, 2015 10:39 PM
Superman09
Sep 25, 2015 05:55 AM
dirt track racer 81
Sep 21, 2015 06:44 PM
5.3lSilverado
Sep 20, 2015 06:48 PM
