Timing set and oil pump
Old Sep 10, 2012 | 09:08 PM
boosted_blue's Avatar
Default Timing set and oil pump
In the middle of my forged 370 build. Block is gen III 6.0L. Cam is Isky triple 12 .56x/.56x lift(3 bolt style). Running a 76mm front mount @ 16-18 psi. I need recommendations on timing sets and oil pumps. Should I run an ls1 HD single, ls2 HD single, ls1 double, or ls2 double? Also curious on oil pumps. What is everyone running? I see my options as a melling stock volume/high pressure pump, melling high volume/stock pressure pump, or should I just run a factory ported unit? Any remmondations or advice is appreciated. Thanks
Old Sep 11, 2012 | 01:03 PM
Bump. I guess nobody runs an oil pump.....
Old Sep 11, 2012 | 03:38 PM
milkey57's Avatar
When i built my motor i went with a stock (new) pump and an ls2 timing chain, been about a year and daily driven no problems here.
Old Sep 11, 2012 | 05:40 PM
TXSZ66AVLANCHE's Avatar
I've run melling stock replacements on all the engines I've built, never had a problem and I play rough with my engines. As long as your bearing clearances are where they are supposed to be....a stock pump is all you need.
Old Sep 11, 2012 | 06:33 PM
sand man's Avatar
go with the 2010 Camaro L99 ( auto trans ) oil pump , its a Higher pressure pump than all wet sump GM pumps ,,just like the melling 10296
Old Sep 11, 2012 | 09:21 PM
Advice on timing sets too please. Single or double?
Old Sep 12, 2012 | 06:15 PM
Suburbazine's Avatar
Only reason to go with a double chain is if the cam you're running is really aggressive, has a high ramp rate, or you're running very high spring pressures. If the cam is mild, an OE set will work fine.
5.3Okasai
Mar 9, 2022 01:07 PM
chopperloco
Jul 10, 2016 10:45 PM
The_W
Oct 28, 2015 09:00 PM
Ammadien
Jul 22, 2015 08:50 PM
Ferocity02
Jul 17, 2015 07:05 PM
